11
I am not a physicist, and I have a hard time getting an intuitive idea of the Lorentz contraction.
Supposing a train gets accelerated from rest to close to the speed a light, its length will be contracted by a certain factor. As observed from an observer in the initial rest frame, will the contraction bring both sides of the train closer to the center (looking like the rear is moving a bit faster, and the front a bit slower)?
What about two trains, one just in front of the other, both accelerated with the same acceleration, starting at the same time. Will the observer at rest observe a gap growing between them as they gain speed? Or will they just both shrink as a single object?
Does the location where the force is applied (the engine of the train) affects the contraction center?
6 Answers6
12
Let's pause there for a moment. In Special Relativity, simultaneity is relative. That means that two event that appear simultaneous in one inertial reference frame are generally not simultaneous in another reference frame.
This means that if two ends of a train began accelerating together in one inertial reference frame, they will not have started accelerating together in a difference inertial reference frame. Things will get very confusing if we don't follow this simple rule.
RULE
Whenever attempting to solve problems in Special Relativity, always use the full Lorentz transformation to find out what the space and time coordinates are for each event in each coordinate system that is of interest.
Don't simply use the abbreviated ideas such as "length" contracts, or "time" dilates. While these abbreviated ideas are true, then leave a lot of important information about what is happening out of view.
End of Rule.
The answer depends upon how the two ends of the train move in the initial rest frame. ONE possibility is that the two ends will not accelerate simultaneously in the rest frame. The back end may accelerate first, causing the back end to accelerate to a speed sooner than the front. The advantage of this type of acceleration is that the train does not get stretched in its own frame (which might cause it to break apart).
Another possibility is that the two ends accelerate "simultaneously" according the the initial rest frame. While this has an appeal to the naive understanding, this means that the two ends will always have the same distance in the rest frame. That means that the train will get stretched in its own frames. Also from its own frames (while moving), the front began accelerating first. (This second possibility is probably not what you mean when you describe a train as accelerating.)
We must ask "both accelerated with the same acceleration" and "starting at the same time" in what inertial frames?
As before the answer depends upon what you mean by "starting at the same time", and "with the same acceleration".
Neil_UK
  • 843
There is a simple intuitive picture for Lorentz length contraction and time dilation that can be understood by anyone familiar with ordinary geometry. It's not perfectly accurate, because spacetime is geometrically different from Euclidean space, but it's easiest to start with the Euclidean picture of what is going on, and then introduce the differences that result from the different geometry.
Take two people out into a field and ask them to start walking at the same speed across the field, but in slightly different directions. For each walker, 'time' is the forward direction, the direction they are walking in, and 'space' is the sideways direction, perpendicular to their path. Each walker sees the other walker slowly drift sideways relative to themselves - they are moving through space - and drifting backwards behind them - they are progressing through time more slowly. Each can see the other walker's clock run slow because each is using a different definition of 'time', a different direction. (Actually, in a Euclidean spacetime moving clocks run fast. This is the difference between Euclidean and Minkowski geometry. I'm glossing over stuff here.)
Each walker carries a metre stick to measure 'space', and holds it perpendicular to their path. Because their paths are tilted with respect to each other, they each see the metre stick of the other tilted with respect to their space and time axes, and so shortened.
Walkers in a field demonstrate length contraction
Each will typically define their coordinate system centred on themselves, and so the shrinking they measure will likewise be centred on themselves. But this is an abitrary choice - there's nothing physical about it. Pick a different origin, and the shrinking will be centred there instead.
The difference between Euclidean space and the geometry of spacetime is based on tweaking Pythagoras' Theorem, so that instead of the square on the hypotenuse being the sum of the squares in the time and space directions, it's equal to the difference between the squares. This has some pretty fundamental and unintuitive consequences. However, the length contraction and time dilation really are just the result of rotating the time and space axes in spacetime, so that lengths look shorter when measured by a ruler when it is tilted at an angle.
Information can travel at most with the speed of light. So if you apply force on the back of the train, the front will not know it should also accelerate until later. This means, the train would shrink in its own frame (i.e. really, physically shrink). This is different effect than Lorentz contraction though, since Lorentz contraction is not physical contraction.
Lorentz contraction has nothing to do with accelerations, forces or their locations. Its simply a way to compare measurement between two different inertial reference frames.
Umaxo
  • 5,928
  • 19
From the point of view of a person standing in the station, your question is: Does the front of the train move before the back, or the back before the front, or both at the same time, or something else? And the answer is: Anything at all, depending on what forces you apply to the train.
In a frame where the front of the train starts moving forward before the back starts moving, the train expands. In a frame where the back starts moving before the front, the train contracts. In a frame where the front and back start moving at the same time, the length of the train does not change. Any of these things could be true in the station frame, again depending on what forces you apply.
Once the train has expanded or contracted, internal forces might or might not cause it to revert to something closer to its original length (and/or to break apart) but this would depend very much on the details of how the train is constructed and I think it is appropriate to ignore it for a question at this level.
Following the expansion/contraction, the train will always be longer in its own ("moving") frame than in the station frame. This might be because the train expanded in its own frame but did not change length in the station frame. Or it might be because the train contracted in the station frame but did not change length in its own frame. Or many other things. If you tell me how the train started moving, I can choose among these. If not, your question is ill-posed.
Notice that you don't really need relativity to attack this question. Tell me how the front of the train and the back of the train move in the station frame, and I will tell you what the contraction (or non-contraction, or expansion) looks like in the station frame. Relativity is about comparing what happens in two different frames, but you are asking about how things look in one particular frame, so you don't need relativity.
WillO
  • 18,387
Assuming a not very long train and a not very large acceleration, then all train cars are moving approximately at the same speed, and are contracted by approximately the same amount. So at high speed the the rear is x meters closer to the middle and the front is x meters closer to the middle. So there seems to be such point about which symmetry is the greatest, the middle point.
About two trains, one just in front of the other: At high speed the front train's rear is closer to the front train's middle and the rear train's front is closer to the rear trains middle. So a gap has formed.
And it doesn't matter where the engine is located.
If the acceleration is large or the train is long, then everything becomes more complicated, because contraction motion starts causing contraction. Are we interested about this case? I mean during the acceleration things are complicated, not when cruising at high constant speed.
stuffu
  • 2,374
-1
The analysis below assumes the trains are perfectly rigid objects, and do not compress or stretch in a mechanical sense. That is, we ignore the physical stresses that the trains undergo, and ignore the time it takes for those stresses to propagate through the train.
That depends on what you as an observer consider "the centre". When a stationary train would shrink you can speak about which way and how much the front and back of the train move. But how do you determine that for a moving, accelerating train? It suffices to say that the back of the train is accelerating slightly more than the front of the train, causing it to shrink with higher speeds.
Assuming they are both accelerating the same according to the outside observer, it depends on where on the train that acceleration is applied. Remember, the back of each train accelerates a bit more than the front. The gap between them will grow, if identical external acceleration is applied to the same location on each train (e.g. to the back of each train). If the acceleration of the back of the leading train is the same as the acceleration of the front of the trailing train, then the gap will stay the same.
They won't shrink as a single object (reducing the gap), unless they are a single physical object, that is they are connected with some physical, rigid structure. But in that case it is not physically possible to apply the same acceleration to both of them. You need to apply more acceleration to the trailing train than to the leading train, otherwise the physical connection between them will break.
As stated above, it does not make much sense to talk about the contraction centre. Note also, the if the engine is on the train, and applies a constant force to the train in that trains reference frame, then the acceleration according to the outside observer is not constant over time.
fishinear
  • 895
  • 15
