-1
I am trying to drive that $[\alpha]=\mathrm{rad}/\mathrm{s^2}$ from $$\tau=I\cdot\alpha.$$ My try: $N\cdot m=\mathrm{kg}\cdot m^2 \cdot [\alpha]$, and as Newton is $\mathrm{kg}\cdot m/\mathrm{sec}^2$ then I got $$[\alpha]=\frac{m\cdot \mathrm{kg}\cdot \frac{m}{\mathrm{sec}^2}}{\mathrm{kg}\cdot m^2}=\frac{1}{\mathrm{sec}^2}?$$
Thanks
You are correct; the "rad" term does not appear in your answer because the number of radians an angle is is defined as the ratio of the arc of the sector it sweeps through to the radius of that sector. This ratio between two lengths ends up being a dimensionless number with no units, as it's a quantity in metres divided by a quantity in metres, despite the fact that its meaning may most effectively be communicated with the companion term "radians".
You can think of your answer as equivalent to (m/m)/s²; in informal terms, you might think of this as "the acceleration (m/s²) experienced by a point in an object on its circular path around the centre of mass, per unit length of the distance of that point away from the center of mass (1/m)", which has the same meaning as "the angular acceleration of the points in the object".
Leo Webb
  • 494
