The answer depends on whether or not you include pressure effects in your analysis. If you assume that your body is very strong, then it will not burst in a vacuum and James Hoyland's radiative heat transfer analysis will hold true.
If instead you assume that your body is not very strong, then you will very rapidly explode when exposed to a vacuum before significant radiative heat transfer has a chance to occur.
In the case of a Deschele Schilder "kaboom" event, the analysis would proceed as follows:
We assume for an estimate that Deschele Schilder consists entirely of water at body temperature and ambient pressure (exactly how much water is to be determined by Deschele Schilder). Assume also a spherical Deschele Schilder. We'll place a 90 watt light bulb in the center of the sphere and power it with physics magic, although it won't affect the analysis.
Then before Deschele Schilder can escape this gruesome fate, we thrust Deschele Schilder into a hard vacuum, and then very quickly consult the phase diagram for water (it would help to have the phase diagram book open to the appropriate page before the start of this experiment).
This will tell us that the spherical volume of Deschele Schilder-flavored water will experience a vapor explosion, in which the enthalpy required to effect the phase change is already stored in the water itself, so it boils into vapor all at once, everywhere within the volume at the same time.
Now we have a spherical volume of water vapor at room temperature which is allowed to freely expand into a near-vacuum, at an effective temperature of ~2.3 K, and obtain our Deschele Schilder kaboom (actually, in the airless vacuum of outer space, we wouldn't hear the kaboom but we could in principle see it).
In a free expansion, the only work performed is on the mass of the expanding material itself, which will be accelerated by the pressure inside the sphere of boiling Deschele Schilder.
Can one of the experts here pick up the analysis and estimate the departure velocity of the Deschele Schilder vapor in the vacuum? Thanks in advance ;-)
