If the electric field strength is $E_x=x, E_y=E_z=0$, then by $\nabla\cdot E=\frac1{\epsilon_0}\rho_e$ where $\rho_e$ is the density of charge, we get $\rho_e=-1$ for any point in the space.
But if $\rho_e=-1$ for any point in the space, then the distribution of charge in space is completely symmetric, so we shouldn't get a $\vec{E}$ which only have $E_x$ component.
I am really confused. Can you explain it for me?
oyyko
Think about the case where $\rho = 1$ between $x = -x_0$ and $x = x_0$, and two charged planes of $\sigma = -x_0$ at $x = \pm x_0$ . You get $E_x = x$ with this setup inside the interval, and zero field outside. Now let $x_0 \to \infty$, and you get the desired field strength, with some strange charge setup at infinity.
ATP
  • 51
It cannot exist, as it requires an infinite amount of charge and an infinite energy to concentrate this. It also conflicts with average charge neutrality.
Perhaps it is instructive to consider a uniformly charged spherical shell. This is an two dimensional implementation of your idea. The component of the electric field parallel to the surface is indeed zero.
my2cts
  • 27,443
-1
This makes a perfect sense if you consider a plane volume of a finite thickness and the variables inside it.
