In the context of critical phenomena, there are several critical exponents commonly used to characterize the singular behaviour at the point of phase transition. The Fisher exponent $\eta$ is defined through \begin{equation} C(T,x) = \frac{ \tilde{C} (x/\xi)}{|x|^{d-2+\eta}} \end{equation} where $C$ is order parameter correlation function with typical correlation length given by $\xi$, $T$ is the control parameter (eg temperature in Ising model), $x$ is spatial coordinate in $d$ dimensions, and $\tilde{C}$ a scaling function.
I have seen it is stated in multiple places that a non-zero value for $\eta$ implies the correlated regions in the system have fractal structures, but I have no clue what the basis for that statement could be. I'd appreciate it if someone can explain this, and also possibly a physical intuition into how the Fisher exponent appears in the correlation function.
SaMaSo
  • 538
