-3
How is charge "stored" if there is no internal structure?
releseabe
  • 2,286
The thing we describe as charge is a coupling constant between two quantum fields. All elementary particles are described by a quantum field, and for a quantum field the charge is the strength of the interaction with the photon quantum field. So it is a fundamental property of the field, not some variable that needs storing.
I suspect the confusion has arisen because electrons and positrons are described by different quantum fields and those fields have different values for the charge. It is not the case that there is one single field and we have to somehow store the value of the charge differently for particles and antiparticles.
John Rennie
  • 367,598
One has to realize that physics is the tabulation of observations in nature using mathematical models, which are called theories, by imposing on the models extra axioms called laws , postulates, principles . The theories are validated if they can predict new observations. And these physics theories are valid in specific regions of the variables, not for all space and all time.
Electrons and positrons belong to the quantum mechanical frame , which, present day mainstream physics postulates is the underlying frame from which all other theories emerge in the appropriate limits.
Observations and data since last century, have solidified at present to the standard model of particle physics where it is axiomatically assumed that the elementary particles (and corresponding antiparticles) are point particles with the assigned charge in the table.
Axiomatic means that "there can be no question", the theory hangs together assuming the axioms are true. If it is a bad theory, it will fail in predicting new data and observations, BUT the standard model is continually validated by new data.
If electrons lack internal structure, how are there also positrons?
All elementary particles in the table lack internal structure and all charged ones have an antiparticle with the same mass and the negative charge. It is an observationally validated fact .
It may be that in the future , people working on deterministic theories that attempt to fit the same data as the quantum mechanical theories, but give internal structure to what are considered point particles now, may succeed. BUT the new theories must embed the successes of quantum mechanics in modelling nature, and either use similar axioms for charge for elementary internal constituents, or have in the theory a mechanism for generating charge. At present the charge of elementary particles is assigned axiomatically, in order to fit data and observations. That is why the positron has the opposite charge of the electron.
anna v
  • 236,935
