-2
This was 3rd beer idea, so please bear with me. What if the universe was not actually expanding but the speed of light was slowing? Wouldn't that be indistinguishable to our observations? Either way we should see an increase in the redshift the further a light source is from us?
Suppose we're in a giant extremely advanced compute cluster, and the speed of light has to do with how long it takes data to travel between compute resources on the network/bus. As more data travels across this bus (entropy increases in the universe) it takes longer to reach its destination (speed of light slows.) This seems vaguely reasonable considering fundamental limitations past and present on computers of varying types, there's always a trade off between size of data and speed of access that has it's roots in physics.
So I know it's a bit wacky, but it sounds easily falsifiable to me, simply plot entropy over time and dark energy over time and see how well they correlate (or don't most likely.)
Can anyone help me test my armchair theory? I think that would be a fun exercise. I know dark energy has been plotted over time, but what about entropy, is that possible?
Eloff
  • 226
How do we know the universe is expanding and the speed of light isn't slowing instead (thanks to innisfree for the idea of where to look.) From wikipedia
By the 1990s and on into the twenty-first century, a number of falsifying observations have shown that "tired light" hypotheses are not viable explanations for cosmological redshifts.[2] For example, in a static universe with tired light mechanisms, the surface brightness of stars and galaxies should be constant, that is, the farther an object is, the less light we receive, but its apparent area diminishes as well, so the light received divided by the apparent area should be constant. In an expanding universe, the surface brightness diminishes with distance. As the observed object recedes, photons are emitted at a reduced rate because each photon has to travel a distance that is a little longer than the previous one, while its energy is reduced a little because of increasing redshift at a larger distance. On the other hand, in an expanding universe, the object appears to be larger than it really is, because it was closer to us when the photons started their travel. This causes a difference in surface brilliance of objects between a static and an expanding Universe. This is known as the Tolman surface brightness test that in those studies favors the expanding universe hypothesis and rules out static tired light models.
Eloff
  • 226
