The real number axis is asymmetric against zero: for instance, multiplication of two negative or two positive numbers will produce a positive number, a square root of a negative number is not real, natural exponent of real numbers is always positive, etc.
On the other hand, the imaginary axis is totally symmetric against zero: every truth about $i$ is also true about $-i$ up to isomorphism. The same is true for other axes in all hypercomplex number systems that I know, including split-complex, dual numbers, bicomplex numbers, tessarines, quaternions, split-quaternions...
I also know that in physical space we also have one anisotropic axis (time) and three symmetric spatial axes. This is true both for classical spacetime of Minkowski spacetime (whose metric is isomorphic to the metric of 4-dimensional split numbers).
As such, a question emerges, whether the real axis is naturally linked to the time dimension, because it is the only non-symmetric axis? Is the existence of no more than one asymmetric physical axis determined by the laws of algebra?
Anixx
  • 11,524
