In a previous question, the metric in the frame of reference of a rotating disc takes the following form:
\begin{align} ds^2 &= - dt^2 + dx^2 + dy^2 + dz^2\\ &= -\left(1 - \omega^2 ({x'}^2 + {y'}^2) \right){dt'}^2 + 2 \omega (- y' dx' dt' + x' dy' dt') + {dx'}^2 + {dy'}^2 + {dz'}^2. \end{align}
Or in cylindrical coordinates,
$$ds^2=-(1-r^2\omega^2)dt^2 +2\omega r^2 dt d\theta + r^2d\theta ^2+dr^2+dz^2$$
As discussed in the linked question, the spacetime described by this metric is still flat because it is simply a coordinate transformation of Minkowski space. The curvature of the spacetime does not depend on what coordinates you choose.
However, I'm puzzled why this reasoning does not agree with Ehrenfest's Paradox, which states that the geometry on a rotating disc is non-Euclidean. Ehrenfest's Paradox has been mentioned multiple times on the site (here and here), but most explanations deal with the rigidity of the disc, none of which mention this metric.
I have a few questions:
  • If Minkowski space is always flat regardless of what coordinates you choose, why is the spacetime geometry of the rotating disc in Ehrenfest's Paradox curved?
  • Does this metric above describe the same situation as in Ehrenfest's Paradox? If so, why doesn't the intuitive length contraction effect along the $\theta$-direction appear in the metric above? The metric accounts for time dilation effects, but not for length contraction. If the metric doesn't describe the same situation, please explain why. (From online sources, I think the correct metric is the Langevin-Landau-Lifschitz metric, but I really can't understand the derivations.)
  • Is there a distinction between the length scale on a physical object and with space itself? For example, would the proper length of a stick be the same as the proper distance between two events in empty space on the ends of where the stick would be? If not, I don't see why arguing about the rigidity of the disc has any consequence on the actual geometry of space.
