If we consider a cylinder along the $z$-axis, with charge density $\rho(z)$ [varying linearly according to$\rho = az + b$, from the positive value $\rho_1=-ha+b$] at $-h$ to the also positive $\rho_2=ah+b$ at $h$), the total charge is $Q\neq0$. In that case, how can we find direction of the dipole moment? Because of rotation symmetry, $\vec{p}$ should be oriented along $z$-axis $\vec{p} = (0,0,p_z)$. Can we say, that the vector points in the direction of a place with higher charge density? I think that if total charge $Q\neq0$, the result depends on the coordinate origin.
Asked
Active
Viewed 113 times
You are right, since the total charge is not zero, the dipole moment depends on the point of reference:
The dipole moment with respect to the point at $\vec{x}_0$ is
$$\vec{p}_{x_0}=\int d^3\vec{x}\,\rho(\vec{x}+\vec{x}_0)\,\vec{x}\,\,\,.\tag{1}$$
Performing a change of variable $\vec{x}+\vec{x}_0=\vec{y}$ in the integral,
$$\vec{p}_{x_0}=\int d^3\vec{y}\,\rho(\vec{y})\,(\vec{y}-\vec{x}_0)=\int d^3\vec{y}\,\rho(\vec{y})\,\vec{y}-\vec{x}_0\int d^3\vec{y}\,\rho(\vec{y})=\vec{p}_{origin}-Q\vec{x}_0,$$
where $Q$ is the total charge.
AFG
- 2,363
