In my notes we are given that for $N$-vortices with location ${(x_i,y_i)}^N_{i=1}$ and stegnth ${\Gamma _i}$.
We have the conserved quanitites of energy, momentum and angular momentum.
How does one prove these to be true. (i am looking for method that doesn't use Hamiltonian if possible)
Jack Jack
  • 187
I assume the following is known. Velocity of i-th vortex is given by $$ \bar{v}_i=\sum_{j\neq i} \Gamma_j \frac{[\hat{\omega}\times \bar{r}_{ij}]}{r^2_{ij}},\quad (1) $$ where $\hat{\omega}$ is a unit vector directed out of the plane and $\bar{r}_{ij}=\bar{r}_{j}-\bar{r}_{i}$ is a vector, connecting i-th and j-th votices and $\Gamma_j$ is the borticity of the j-th vortex. Interaction energy of i-th and j-th vortices is $$ U_{ij}=-\frac{1}{4\pi}\Gamma_i\Gamma_j \ln(r_{ij}). $$ Here are the rough sketches of the proofs of the conservation laws.
Energy conservation. Taking time derivative from the sum of all interaction energies, we obtain $$ \dot{U}=\sum_{ij}\dot{U}_{ij}=-\frac{1}{4\pi}\sum_{ij}\Gamma_i\Gamma_j \frac{\bar{v}_j-\bar{v}_i}{r_{ij}^2} $$ We can notice that $\dot{U}_{ij}=-\dot{U}_{ji}$, which ensures that the above sum is zero, and therefore the energy is conserved.
Momentum conservation. Momentum of the system is $$ P=\sum_i \Gamma_i \bar{v}_i $$ Substituting here Eq. (1) and accounting for $\bar{r}_{ij}=-\bar{r}_{ji}$, yields $P=0$.
Angular momentum conservation. Angular momentum of the system is $$ M=\sum_{i} M_i=\sum_{i} [\bar{r}_{i}\times\Gamma_i\bar{v}_i ]. $$ Substituting Eq. (1), expanding cross-product and accounting for $\hat{\omega}$ being perpendicular to the plain, we obtain $$ M=\sum_{ij,i\neq j} M_{ij}=\sum_{ij,i\neq j}\Gamma_i \Gamma_j \frac{\hat{\omega}(\bar{r_i},\bar{r_j}-\bar{r_i})}{r_{ij}^2} $$ One can notice that $M_{ij}+M_{ji}=\Gamma_i\Gamma_i\hat{\omega}$, which makes the whole sum equal to $$ M=\sum_{ij,i\neq j}\Gamma_i \Gamma_j \hat{\omega}, $$ which is clearly a conserved quantity.
Pavlo. B.
  • 2,605
