I'm working on a problem regarding two objects with the same kinetic energy.
Two objects with masses of $m_1$ and $m_2$ have the same kinetic energy are both moving to the right. The same constant force F is applied to the left to both masses. If $m_1=4m_2$, the ratio of the stopping distance of $m_1$ to that of $m_2$ is:
I believe the key information here is that both objects have the same kinetic energy. This must mean that an equal amount of work (force $\times$ distance) must be applied to each object in order to bring it to a complete stop ($KE + q = 0$)?
Is the correct answer $1:1$?
Colin McFaul
  • 4,379
Yes, you have spotted the key fact from the question.
The heavier mas is going 1/2 as fast, and experiences 1/4 the acceleration, which by v^2 = 4ad rearranged as d = v^2/4a, shows that the ratio of stopping distance for both objects will be identical.
Answer is 1:1. Here is how you can derive it
Since kinetic energy is equal
1/2 (m1*v1^2)=1/2 (m2*v2^2) => 4m2 *v1^2 = m2*v2^2 taking root on both sides
2v1 = v2
Since Force is equal, deacceleration a1 = F/m1 and a2= F/m2
Now use v^2 = u^2-2as for both and derive s1:s2 = 1:1
abhinav
  • 117
