I'm trying to understand the conservation of momentum in general relativity.
Due to the curvature of space-time by matters and energy, the path of a linear motion appears to be distorted.
Therefore from the frame of reference of an observer who is at a not-so-curved region of space-time, it appears that the velocity vector of an object that is moving along a straight line in a very-curved space-time is changing?
Does that imply that from the observer's frame of reference (in a not-so-curved space-time) momentum of that object (in the very-curved space-time) is not conserved?
In this sense is momentum not always conversed in general relativity or did I misinterpret something?
Bryan
  • 173
"I'm trying to understand the conservation of momentum in general relativity.
Due to the curvature of space-time by matters and energy, the path of a linear motion appears to be distorted."
One first step in understanding the concept of "curvature" is the bending of a light beam from a star by the gravitation of the sun (first seen during a eclipse of the sun, considered proof of Einstein's theory). If a photon has zero mass how can it be radially accelerated and deviated in its course by gravitation (F equals mass times acceleration; what if mass is zero, or, conversely, what if there is no gain of speed)?
A photon cannot be accelerated as there exists the speed limit of "c" - neither can it be accelerated by gravitation nor any impulse in terms of Newtonian laws.
Thus, to understand the "curvature of space" and the concept of "conservation of momentum in relativity" it is important to acknowledge that the Newtonian laws which are true must be reconciled with reality when it comes to speed of masses that approach the speed of light.
If you explain the inflection of light by postulating space curvature you are exempt from assum ing forces to apply on massless particels to explain their trajectory.
On the other hand, any massless particle or close-to massless particle does not obey the Newtonian laws of acceleration, as it is found that impulse exerted on the particle by gravitational or other forces does not translate into a gain of velocity of those particles that would correspond to Newton's law. As the gain of energy of those particles that does occur (shift of wavelenght in gravitational field or accelerator instead of velocity gain) is able, vice versa, to translate into mechanical impulse that can be exerted by the particles ("on sun sail") this gain of energy can be translated into and defined in terms and units of Newton's mechanical laws.
The latter concept is known as "relativistic mass" and as a concept is parallel to explaining the inflection of a massless photon by the gravitational field by "curvature of space".
To test the explanation above on "curvature" and "conservation of momentum" take some accelerated electron that escapes from some accelerator to space. Will it be deviated by gravitation of the earth according to its rest mass that is known and fixed, or, according to its relativistic energy?
-2
When a particle is deflected by gravity the gravitational field will also be modified by the particle. To form a conservation law for momentum you need to take into account the momentum in the gravitational field as well as the particle. This can be done e.g. using pseudo-tensor methods.
This works but remember that momentum is a relative concept. Even in Newtonian dynamics it depends on the velocity of your reference frame. In general relativity it also depends on the frame but a much wider class of frames is valid. This means that momentum conservation depends on the choice of co-ordinates. Locally you can pick an inertial reference frame but over extended regions there is no inertial frame. A momentum in one location cannot be simply added to a momentum vector in another location.
Nevertheless, momentum conservation laws over extended regions do work correctly in general relativity. For an extended description of the formalism and why it works see my article at http://vixra.org/abs/1305.0034
Edit: In the comments below MWT p457 has been cited to support the idea that energy and momentum are only conserved in specific cases. I am adding this to directly refute what has been said there.
MWT begin by saying that there is no such thing as energy or momentum for a closed universe because "To weigh something one needs a platform on which to stand to do the weighing" This is pure Wheeler rhetoric of the type for which he is greatly admired, but in this case it is simply misleading. Weight is a Newtonian term with no useful counterpart in general relativity except in the specific case of an isolated system in an asymptotically flat spacetime. For other situations such as the closed cosmology energy and momentum conservation take a different but equally valid form.
They go on to say that in a closed universe total energy or momentum or charge is "trivially zero" They justify that it is zero because you can use Gauss's divergence theorem to write the charge, energy or momenta as a boundary integral. For a closed universe the boundary disappears making the result zero. This is of course correct, but they give no justification for calling this answer trivial. Energy and momenta are initially defined as a sum of volume integral contributions from each physical field including electromagnetic fields, fermionic fields, gravitational field etc. It is in this sense that we understand that conserved quantities can move and can transform from one form to another but the total remains constant. It is a property of gauge fields that when the dynamical field equations are used the conserved quantity is the divergence of a flux from just the gauge field so that it can be integrated over a volume and be calculated as a boundary surface integral. This gives charge/energy/momenta a holographic nature where they can be considered either as a volume integral over contributions from different fields of a surface integral over the gauge field flux. The important thing to understand is that to go from the volume to the surface form the field equations must be used. This means that the total charge/energy/momenta in a closed universe is zero but that this is not in any sense a trivial result. If you calculate total energy as a volume integral for a configuration of fields that do not satisfy the equations of motion the answer will not necessarily be zero. Stating that it is zero is therefore making a non-trivial assertion about the dynamics. This is what conservation laws are all about.
MWT go on to explain why it would make no sense to have an energy-momentum 4-vector globally. The invalid assumption they are making is that energy and momenta need to form a 4-vector. A 4-vector is a representation of the Poincare group and is the natural form that energy-momentum takes in special relativity where Poincare invariance is the global spacetime symmetry. In general relativity the global spacetime symmetry is diffeomorphism invariance so the correct expectation is that all quantities should take the form of a representation of the diffeomorphism group for the manifold. This is what happens. If you demand an energy-momentum 4-vector then of course you will only get an answer locally, and also for an asymptotically flat spacetime where Poincare symmetry is valid at spatial infinity, but demanding such a 4-vector is simply the wrong thing to do in general relativity.
In the fully general case of any spacetime we can apply Noether's theorem using invariance under diffeomorphism generated by any contravariant transport vector field (Observe that it is invariance of the equations that is required, not invariance of the solutions. Some people like to confuse the two) The result is a conserved current with a linear dependence on the transport vector field. This is the correct form for a representation of the diffeomorphism group. I refer to my cited paper for the mathematical details.
This current gives conservation laws for energy, and momenta including generalizations of angular momenta as well as linear momenta depending on the transport vector field chosen. If it transports space-like hypersurfaces in a timelike direction it will give an energy conservation law and if it transports in spacelike directions it gives momenta conservation laws. These energy and momenta do not normally form 4-vectors but they can be integrated to give non-trivially conserved quantities. The global form a conservation law must take is that the total energy and momenta in a volume must change at a rate which is the negative of the flux of the quantity over the boundary, and this is what you get with the currents derived from Noether's theorem.
It may be that other people will want to add comments here that dispute the validity of energy conservation in other ways. I refer once again to my new article at http://vixra.org/abs/1305.0034 where I refute all the objections that I have heard. Triviality is dealt with in item (6) and 4-momentum is dealt with in item (8). Unless someone comes up with a novel objection I will just refer to the numbered objections in this paper in future.
Remember, there are no authorities in science and any expert may be shown to be wrong either by reasoning or by experiment.
