Let us consider a two terminal electrical component. It is typical to calculate the power it consumes by considering the voltage drop $U$ and the current passing through it $I$ and to say it absorbs a power $P=U.I$ (of course voltage and current should be oriented in the appropriate manner to say that it absorbs this power). I emphasize on the fact that this formula is also used when varying-in-time fields are considered (the instantaneous power reads $P(t)=U(t)I(t)$)
Now, from electromagnetism theory, we know (among other things) that:
$$\mathbf{E}=-\mathbf{\nabla} V - \partial_t \mathbf{A}$$ $$\mathbf{B}=-\mathbf{\nabla} \wedge \mathbf{A}$$ $$\mathbf{\nabla} \wedge \mathbf{B}=\mu_0 \mathbf{j} + \mu_0 \epsilon_0 \partial_t \mathbf{E}$$
In electrostatic regime, the relationship between voltage drop around two points $A$ and $B$, and electric field is simply:
$$U=\int_A^B \mathbf{E}.\mathbf{dl} $$
This is "consistant" with the general expression of the electric field I gave in term of potentials, assuming $\partial_t=0$
Question1:
What happens in the varying regime ? To what the $U$ in $P=U.I$ corresponds to ? Is it still the line integral of the electrical field ? If so, the voltage drop now depends on the precise path where the integration has been performed because we also integrate the quantity $\partial_t \mathbf{A}$. Then it is not really well defined because we don't need to specify "a path" when we talk about the voltage around a two terminal electrical component in varying regime.
Or maybe the answer is to take in general the "path independant" quantity:
$$U=\int_A^B (\mathbf{E}+\partial_t \mathbf{A}).\mathbf{dl} $$
Question2:
If the voltage drop is still defined as $U=\int_A^B \mathbf{E}.\mathbf{dl} $, how to make sense of the fact such definition depends on the exact path of integration ? Is there a way to make sense of it in the lumped-approximation regime, which means that we don't see spatial variation of electrical waves around the size of the electrical element we are considering ?
