In David Tong's Quantum Field Theory Lecture Notes, Page 115 Eq. 5.34, the Feynman propagator was defined to be
$$ S_F(x-y)=\langle 0|T\psi(x)\bar\psi (y)|0\rangle \newcommand{\normord}[1]{:\mathrel{#1}:\;}. \tag{5.34} $$
However, in Eq. 5.36,
$$\mathrm{contraction}(\psi(x)\bar\psi(y))=T(\psi(x)\bar\psi(y)) \ -\normord{\psi(x)\bar\psi(y)} =S_F(x-y), \tag{5.36}$$
which seemed to indicate that $$\normord{\psi(x)\bar\psi(y)}=0.$$
What happened here? How did Wick's theorem work for Feynman propagator in Dirac Equation?
Note that the LHS of eq. (5.56) is an operator. This implies that there is an implicitly written identity operator ${\bf 1}$ on the RHS of eq. (5.56). By sandwiching eq. (5.56) with the vacuum state, we only get $$\langle 0 | :\psi(x)\bar\psi(y):|0\rangle~=0;$$ not OP's last equation.
There is an analogous situation for bosons. For more details, see e.g. this related Phys.SE post.
It's not true $:\psi(x)\bar\psi(y):=0$, but it is true that $\langle0|:\psi(x)\bar\psi(y):|0\rangle=0$.
I just looked up Tong's notes and it looks like he works out a specific example in detail for the bosonic case at eq 3.33 that may be helpful to you.
octonion
  • 9,072
