56
  • Classical mechanics: $t\mapsto \vec x(t)$, the world is described by particle trajectories $\vec x(t)$ or $x^\mu(\lambda)$, i.e. the Hilbert vector is the particle coordinate function $\vec x$ (or $x^\mu$), which is then projected into the space parametrized by the "coordinate" time $t$ or the relativistic parameter $\lambda$ (which is not necessarily monotonous in $t$).
    Interpretation: For each parameter value, the coordinate of a particle is described.
    Deterministic: The particle position itself
  • Quantum mechanics: $x^\mu\mapsto\psi(x^\mu)$, (sometimes called "the first quantization") yields Quantum mechanics, where the Hilbert vector is the wave function (being a field) $|\Psi\rangle$ that is for example projected into coordinate space so the parameters are $(\vec x,t)$ or $x^\mu$.
    Interpretation: For each coordinate, the quantum field describes the charge density (or the probability of measuring the particle at that position if you stick with the non-relativistic theory).
    Deterministic: The wave function
    Non-deterministic: The particle position
  • Quantum Field Theory: $\psi(x^\mu)\mapsto \Phi[\psi]$, (called the second quantization despite the fact that now the wave field is quantized, not the coordinates for a second time) basically yields a functional $\Phi$ as Hilbert vector projected into quantum field space parametrized by the wave functions $\psi(x^\mu)$.
    Interpretation: For each possible wave function, the (to my knowledge nameless) $\Phi$ describes something like the probability of that wave function to occur (sorry, I don't know how to formulate this better, it's not really a probability). One effect is for example particle generation, thus the notion "particle" is fishy now
    Deterministic: The functional $\Phi$ Non-deterministic: The wave function $\psi$ and the "particle" position
Now, could there be a third quantization $\Phi[\psi(x^\mu)] \mapsto \xi\{\Phi\}$? What would it mean? And what about fourth, fifth, ... quantization? Or is second quantization something ultimate?
9 Answers9
38
One more answer against “second quntization”, because I think it is a good demonstration of how a lame notation can obscure a physical meaning.
The first statement is: there is no second quantization. For example, here is citation from Steven Weinberg's book “The Quantum Theory of Fields” Vol.I:
It would be a good thing if the misleading expression ‘second quantization’ were permanently retired.
[I would even say that there is no quantization at all, as a procedure to pass from classical theory to quantum one, because (for example) quantum mechanics of single particle is more fundamental than the classical mechanics, therefore you can derive all “classical” results from QM but not vice versa. But I understand that it is a too speculative answer.]
There is a procedure called “canonical quantization”, which is used to construct a quantum theory for a classical system which has Hamiltonian dynamics, or more generally, to construct a quantum theory which has a certain classical limit.
In this case, if by the “canonical quantization” of a Hamiltonian system with finite number of degrees of freedom (classical mechanics) you imply quantum mechanics (QM) with fixed number of particles, then quantum field theory (QFT) is the “canonical quantization” of a classical Hamiltonian system with infinite number of degrees of freedom - classical field theory, not quantum mechanics. For such procedure, there is no difference between quantization of the electro-magnetic field modes and quantization of vibrational modes of the surface of the droplet of superfluid helium.
One more citation from Weinberg's book:
The wave fields $\phi$, $\varphi$, etc, are not probability amplitudes at all...
It is useful to keep in mind the following analogy: the coordinates are the “classical configuration” of a particle. QM wave function $\psi(x)$ corresponds to the “smearing” of a quantum particle over all possible “classical configurations”. QFT wave function $\Psi(A)$ corresponds to “smearing” of a quantum field over all possible configurations of a classical field $A$. Operator $\hat{A}$ corresponds to the observable $A$ in the same way as observable $x$ is represented by Hermitian operators $\hat{x}$ in QM.
The second statement is: “canonical quantization” is irrelevant in the context of fundamental theory. QFT is the only way to marry quantum mechanics to special relativity and can be contracted without a reference to any "classical crutches"
Conclusion: There is not any sequence of “quantizations” (1st, 2nd,.. nth).
The (first) quantization is a sound mathematical procedure: usually it associates to a function of two variables $a(x,\xi):\mathbb{R}^d \times \mathbb{R}^d \to \mathbb{C}$, an operator $a(x,D_x)$ ($D_x$ is the derivation multiplied by $-i$) on $L^2(\mathbb{R}^d)$. There are various types of quantization (e.g. Weyl, Wick, Anti-Wick, Born-Jordan) that deal differently with the ambiguities in the ordering of the multiplication operator $x$ and the derivation $D_x$. The physical interpretation in quantum mechanics is straightforward: a classical function of position and momentum corresponds to an operator (depending on the quantum canonical variables) on the Hilbert space.
The Fock space of quantum field theory is an infinite sum of Hilbert spaces, each one tensor product of the one-particle space ($L^2$), properly symmetrized. Due to its particular structure, to a given operator on the one-particle space can be associated an operator on the full Fock-space. This procedure can be made again rigorous from a mathematical standpoint, and it is called second quantization. The name is due to the analogy to the quantization described above: the one-particle operator is the analogous of the phase space function, and the operator on the full Fock space depends on the canonical variables, i.e. the creation and annihilation operators. It is possible to first quantize a function of the phase space, and then second quantize the result to obtain an operator of the Fock space.
This is just a matter of terminology; nevertheless it is the standard procedure utilized to deduce the structure of quantum systems, starting from what we can easily observe (the classical analogues). Quantization is also a very powerful mathematical tool, even if it may be seen as the opposite of how nature works.
The Fock space can be constructed starting from any separable Hilbert space, and the Fock space is a separable Hilbert space. So we can think of a Fock space of Fock spaces. Let $\Gamma(L^2)$ be the first Fock space, and $\Gamma(\Gamma(L^2)) $ the second. Then the second quantization of an operator on $\Gamma(L^2)$ would result in an operator on $\Gamma(\Gamma(L^2))$, and we may call it the third quantization of the operator. Obviously this idea can be iterated to obtain $n$th quantization. But, apart from being a mathematical curiosity, I have no idea what the physical interpretation of these further quantizations may be.
For mathematical informations on the procedure of second quantization see for example the second volume of the book of Reed and Simon. For the first quantization you can see the books of Hormander "analysis of linear partial differential operators", especially chapter XVIII; but this book needs a lot of mathematical background.
yuggib
  • 12,357
In the context of quantum field theory Weinberg's advice to ignore the term "second quantisation" is good advice. However, to go beyond quantum field theory anything goes and some people have promoted the idea of multiple quantization as a speculative idea that could be fruitful. It's not a popular idea as you can see from the other answers, but the response to this question would not be complete without mentioning it.
Beware that the term "third quantization" is used in the context of quantum cosmology and does not really mean an extra quantization after second quantization. If you want to learn about the real thing try searching for terms like "multiple quantization", "iterated quantization", "repeated quantization", "fourth quantization" or "infinite quantization" (and ignore anything about data compression.)
You will find that the results are speculative, varied and incomplete, but not always totally mad. I don't think people should get overexcited about the idea but it should not be blithely dismissed either. It's just something to keep in the back of your mind if you are trying to understand the structure of theories about quantum gravity for example.
I agree with Kostya that these names are deprecated and, in this sense, should be avoided (A. Zee's, "QFT in a Nutshell", book makes this point pretty straightforwardly).
Now, if you think of the process of "quantization" as a functor, you get to Baez's constructions. But, note that the objects being acted upon by this 'quantization functor' get progressively different from what you may be expecting.
An example that comes to mind is the quantization of gerbes, which does make an appearance in high energy physics (see section 3 of Geometric Langlands From Six Dimensions). But these objects are very non-intuitive from the Physics point-of-view: you don't even get an Action associated to this construction.
So, at this point, the furthest we've moved in this direction is String Field Theory. But, in some sense, "quantization" is still a mystery…
Daniel
  • 4,255
As far as I understand, string theory is the quantization of a conformal quantum field theory, treated as a classical theory - apparently in precisely the same way as a spinor quantum field is the quantization of the Dirac particle, treated as a classical field. Thus it is a prominent example of third quantization.
Second quantization is a way of recasting things. Second quantization defines fields over the Fock space so formerly waves are now parameters of field amplitudes. I have heard string theory called “third quantization,” but as I see it this is probably an abuse of language. At one time when membranes were first considered the term fourth quantization was raised a few times, though I think more in jest.
In the end it is all just quantization, and Weinberg is probably right in ignoring numberical ordering of quantization. Writing nonrelativistic QM according to $a$ and $a^\dagger$ is called second quantization by some, but really nothing much has changed.
Wow, that's a very good question. Unfortunately, I can't write down a question, because a haven't got one.
Nevertheless, I tried to found something related to third quantization in arxiv, and surprisingly (or not so surprisingly), you can find some papers related to this new step.
Just to name a few:
http://arxiv.org/abs/gr-qc/0606021
http://arxiv.org/abs/hep-th/9212044
I really hope that someone can get a full answer here.
asanlua
  • 600
There's a pretty interesting article where they use a trick that they call "Third Quantization" to study open fermi systems.
http://iopscience.iop.org/1367-2630/10/4/043026 (open access no less!)
It's not exactly what you have in mind, but as clearly illustrated by all of these other answers, "third quantization" is not really canon among physicists.
wsc
  • 5,615
3rd Quant IS not only possible, but is now being employed to develop a quantum theory of the Multiverse. First invented 60 yrs ago by Nambu, it was first employed in string theory (Strominger), as necessary to describe topology change, in analogy to 2nd quant, which is used to explain particle creation/annihilation.
Jimbo
  • 129
