I’ve been messed over on a test (at least one that I can clearly remember, probably at least a few more) (and it was only a few points, but still very frustrating) because I forgot to switch my calculator from degrees to radians when going from physics class to calculus.
Why do they use different measurement systems? Wouldn’t it be best to mainly use one system? What is better about either one that makes them preferred by that class? Specifically, why are radians used in some physics problems while others use degrees?
Doragon
  • 103
Degrees measure angles, while radians actually measure distance (in some sense). This is because a radian is defined as
the angle subtended from the center of a circle which intercepts an arc equal in length to the radius of the circle
(Source)
as can be seen in this animation:
(Source)
This makes the radian particularly useful when talking about rotational motion. For example, saying that you moved a distance of 2 radians makes a lot more sense than saying you moved a distance of, let's say, 30°.
So if you encounter radians, there is most often a (hidden) circle. This is also why radians are most commonly used for descibing trigonometric functions. On the other hand, describing the angle between a light ray hitting a mirror and the surface would usually be given in degrees.
This answer may be a bit unsatisfactory since you could always convert radians into degrees and back and you would be right, but this is the best that I can explain it. I'll leave you some links for further reading:
Radians vs. Degrees - physicsthisweek
Degrees vs. Radians - mathwithbaddrawings
jng224
  • 3,796
Radians is the "big boy" units to use. Degrees are the "baby method" to use. Mainly because they are defined such that there are $2\pi$ radians in an a circle. Meaning $\theta/360 \cdot \pi \cdot r^2$ becomes simply $1/2r^2 \theta$.
$\theta/360 \cdot2\pi\cdot r$ simply.becomes $r\cdot\theta$
It is the most natural units to use.
Degrees were invented due to their easy divisibility.
jng224
  • 3,796
jensen paull
  • 7,016
You could certainly use degrees if you wanted to but there would be annoying factors of $180/ \pi$ everywhere. For example, you know that $v= \omega r$ comes from differentiating $s = r \theta$ with respect to time. Had you done that in degrees you'd have an extra factor of $180 / \pi$ and as a consequence you would also have this factor in almost all the equations of rotational dynamics in classical mechanics.
