I was reading Peter Mann's Lagrangian & Hamiltonian Dynamics, and I found this equation (page 115):
$$p_i := \frac{\partial L}{\partial \dot{q}^i}$$
where L is the Lagrangian. I understand this is the definition of conjugate momentum, but I wanted to know if there is a particular reason for the momentum index to be a lower index and the coordinate index to be an upper index. Is it simply the author's preference or there is a deeper reason?
  1. The index of generalized coordinates $q^1, \ldots, q^n$, is conventionally$^1$ a superscript/upper index in physics.
  2. The Lagrangian momenta $p_i:=\frac{\partial L}{\partial \dot{q}^i}$ have a subscript/lower index since they transform under general coordinate transformations $q^i\to q^{\prime j}=f^j(q,t)$ as components of a co-vector/1-form $p=p_i\mathrm{d}q^i$, cf. e.g. this Phys.SE post.
$^1$ Be aware that many authors don't bother to make such notational distinctions.
Usually, you would write your Lagrangian in some sort of form like:
$$L = {\dot q}^{i}{\dot q}_{i} = g^{ij}{\dot q}_{i}{\dot q}_{j}$$, because the lagrangian itself is a scalar. Then, if you took a variation with respect to the "downed" version, you'd be left with
$$\frac{\delta L}{\delta {\dot q}_i} = 2 g^{ij}{\dot q}_{j} = 2 {\dot q}^{i}$$
So, variation of a scalar with respect to a "downed" index leaves an "upped" index.
