In QED for example, you add the term $$\mathcal{L}_{GF}=-\frac{1}{2\xi}(A_{\mu}A^{\mu})^{2}$$ so you can compute the photon propagator. The question is basically, why you can compute physical observables where at the beginning a $\xi$-dependence appears, and the physical observable ends up with no such dependence, and it doesn't matter whether you choose 't Hooft-Feynman gauge $(\xi=1)$ or Unitary gauge $(\xi=0)$.
Asked
Active
Viewed 300 times
Independence of gauge-fixing is perhaps easiest to understand in the BRST formulation. It turns out that all of the gauge-fixing (including the $\xi$-parameter) can be tucked away inside a BRST-exact part of the action, where it cannot affect BRST-invariant (=physical) observables, cf. e.g. my Phys.SE answer here.
For proofs that does not use the BRST formulation, see e.g. Refs 1-2.
References:
M.E. Peskin & D.V. Schroeder, An Intro to QFT, 1995; section 9.4.
M. Srednicki, QFT, 2007; chapter 71. A prepublication draft PDF file is available here.
