For an affinely parameterised geodesic we can form the Lagrangian: $$ \mathcal L = g_{ab}\dot x^a\dot x^b = \text{constant} $$
The Lagrangian is constant by the fact that the geodesic parallel transforms it's tangent vector, $\dot x^a$, thereby preserving it's length. My question in then this: If the Lagrangian is constant, what meaning can assign to the principle of least action? For a non varying Lagrangian surely the action will not vary with trajectory?
G. Smith
  • 52,489
You could ask the same exact thing for the Lagrangian of a nonrelativistic particle. It's an exactly analogous situation. $$ L = \frac{1}{2} m \dot x^2 $$ Now, if we differentiate the Lagrangian with respect to time, we get \begin{align} \frac{d}{dt} L &= \frac{1}{2} m \frac{d}{dt} \dot x^2 \\ &= m \dot x \ddot x \\ &\neq 0 \end{align} It's not $0$. For instance, if we plug in the trajectory $$ x(t) = A \sin(\omega t) $$ then $$ \frac{d}{dt} L = m \dot x \ddot x = - m A^2 \omega^3 \sin(\omega t) \cos(\omega t) \neq 0 $$ just to give one example.
However, the equation of motion which comes from this Lagrangian is $$ \ddot x \approx 0. $$ Here, the squiggly equals does not mean "approximately" equals, but it means equal "on solutions to the equations of motion." So if you take a path $x(t)$ which extremizes the action, then the second time derivative of $x(t)$ is $0$. However, this isn't true for any random path, like $A \sin(\omega t)$!
Now, using $\ddot x \approx 0$, we get $$ \frac{d}{dt} L = m \dot x \ddot x \approx 0. $$ So, using our new notation, we see that, while $d L/dt$ is not identically $0$, it is equal to zero on solutions to the equations of motion. So $L$ is constant on solutions to the equations of motion, but it's not a constant in general. This distinction is very important. The action principle which comes from $L$ is therefore perfectly well defined.
user1379857
  • 12,195
13
OP's Lagrangian is indeed constant on-shell, but not necessarily off-shell. In contrast, the principle of stationary action compares various possibly off-shell paths.
The basic confusion is "constant in time" versus "constant over trajectories". The action is the time integral of the Lagrangian, and is a "functional" mapping an entire (hypothetical) trajectory to a number. Even if every trajectory had a constant-in-time Lagrangian (which isn't the case -- see other answers), that doesn't mean that the action is the same for every trajectory.
For example, in a given reference frame in flat spacetime, compare two trajectories between spacetime points A and B: motion at a constant speed along a straight line and motion at a (higher) constant speed along a curve (the speed has to be higher to reach point B following the longer path). The Lagrangian, and thus the action, will be greater in the second case even though the Lagrangian happens to be time-independent in both cases. Thus, it is meaningful to say that the straight-line trajectory has the least action.
nanoman
  • 4,058
  • 15
Consider $L= x^2 + y^2 = \text{C} \to \delta L=\frac{\partial L}{\partial x}dx + \frac{\partial L}{\partial y} dy=0\to\frac{dx}{dy}=\frac{-y}{x} \\ \to x=\cos(\theta) \text{ & } dx=-\sin(\theta)d\theta \text{ and } y=\sin(\theta) \text{ & } dy=\cos(\theta)d\theta.$
$L$ is constant but it's possible to find equations for $x$ and $y$ by varying $L$.
$L=g_{ab}\dot{x}^a\dot{x}^b =\text{C}$ only says, in this context, that the tangent vector has constant magnitude. The paths $x(s)$ and the space $g_{ab}$ are variable. Again, you can find how L behaves by differentiating it.
If $2K\equiv g_{ab}\dot{x}^a\dot{x}^b =\dot{x}^a\dot{x}_a $ then you can quickly read off $\Gamma^a _{bc}$ from the geodesic equation in the form
$\frac{\partial K}{\partial x^a } - \frac{d}{ds} (\frac{\partial K}{\partial \dot{x}^a})=0$ where $2K=\text{C}=0,+1,-1$.
Example:
$ds^2 = \eta^2 d\tau^2 - d\eta^2 \to K=\frac{1}{2}(\eta^2 \dot\tau^2 - \dot{\eta}^2 ) $
$\frac{\partial K}{\partial x^a } - \frac{d}{ds} (\frac{\partial K}{\partial \dot{x}^a})=0 \to \frac{\partial K}{\partial \tau } - \frac{d}{ds} (\frac{\partial K}{\partial \dot{\tau}})=0\to2\eta \dot{\eta}\dot{\tau}+\eta^2 \ddot{\tau}=0\to$
$\ddot{\tau}+\frac{2}{\eta} \dot{\eta} \dot{\tau}=0\implies\Gamma^\tau _{\eta \tau}=\frac{2}{\eta}=\Gamma^\tau _{\tau\eta}$
