A coherent state is defined as the eigenstate of the annihilation operator $\hat{a}$. It can be obtained from the vacuum of the number operator by acting with displacement operator: $$|z\rangle=\hat{D}(z)|0\rangle=e^{-|z|^2/2}\exp[z\hat{a}^\dagger]\exp[-z^*\hat{a}|0\rangle\\ ~~~~~~~ =e^{-|z|^2/2}\exp[z\hat{a}^\dagger]|0\rangle$$ where in writing the last step we used $\hat{a}|0\rangle=0.$
Now the BCS ground state of a superconductor, written as (See Superconductivity and SUperfluidity by Annett or QFT by Blundell) $$|\Psi_{\rm BCS}\rangle=\prod_{\vec p}\frac{\exp\left[\alpha_{\vec p}\hat{P}^\dagger_{\vec p}\right]}{\sqrt{1+|\alpha_{\vec p}|^2}}|0\rangle$$ where $\hat{P}^\dagger_{\vec p}=\hat{c}_{\vec p}^\dagger \hat{c}^\dagger_{-\vec p}$ is the Cooper pair creation operator, is also called the BCS coherent state. But it does not look like the usual coherent state that I have written above. Then, why is this called a coherent state?
