I hope you are doing well :)
When I was practicing, I came upon this question:
On a horizontal frictionless surface there is a Spring with a Spring constant is 50 N/m. Initially, the spring is at its relaxed length and a block is stationary at position x = 0. Then an applied force with a constant magnitude of 3.0 N pulls the block in the positive direction of the x-axis, stretching the spring until the block stops. When that stopping point is reached, what is the position of the block?
The question is similar to to this post: Why equating forces give wrong answer?, except that the question in the other post asked for the maximum displacement, and since the system is dynamic, may not be when the block comes to rest. However, the question in this post directly indicates that the block comes to rest.
I thought that since the block was stationary, the applied force would cancel out with the spring force, leading to zero acceleration, so Fapplied + Fspring = 0 ... so doing that, I got -kx + 3 = 0 and since k = 50, -50x + 3 = 0, so x = 3/50 = 0.06 meters. However, the answer key showed that the Work cancels out, meaning Wapplied + Wspring = 0, and got x = 0.12 meters. I would like to know why the Forces don't cancel out, in this scenario, if the block is literally at rest? It would be awesome if someone could help clear my doubt, at your convenience. Thanks, and have a great day!
