Okay, so I gather from the link that $G^{(k)}$ in your notation refers to the correlation between field values at $2k$ points, with $\varepsilon^+$ inserted at half of them and $\varepsilon^-$ inserted at the other half.
This concept of an $n$-point correlation function is very similar to the $n$th moment of a random variable or statistical distribution. For simplicity, consider an example with 1 dimension: A field over 1 time dimension (at a single point in space), described by a random variable. Now, we can consider the probability distribution of this random variable and talk of it's moments. The mean value would be called the 1st moment and the variance would be related to the second moment (it is in fact called the second central moment). Similarly, you can generalize to higher order moments which help characerize the distribution. The moments help you characterize the distribution and also give an intuitive feel for the function.
Generalize this concept to random variables which are fields over many-dimensional spacetime. That is what your correlation functions are.
Btw, for a gaussian distribution (non-interacting fields i.e. quadratic action), all odd moments vanish. (That might be the motivation for $G^{(k)}$ to be defined as the correlation between field values at $2k$ points... even though the actual physical theory you're considering will probably be interacting, else all correlation functions are fairly trivial).
Also, all even moments beyond the 2nd-moment are completely specified by the 1st and the 2nd moment. Ref1 and Ref2
If you had an interaction term in the hamiltonian/lagrangian involving 4 fields, then the 4-point correlation function would have 2 kinds of contributions:
- 2 sets of 2-point correlation functions between pairs of points among those 4 points
- A nontrivial contribution from the interaction term with one of it's field insertions at each of the 4 points.
So you can see that higher order correlations functions give you very important (an unique) information in an interacting physical theory.
Update: The (many) answers to this SE question might also shed some light on the discussion.
