It is well known that straight static cosmic strings don't produce any gravitational effects on test-particles, and that static flat domain walls are repulsive. This can be seen from the linearized theory of Einstein's equation, in the case of static weak fields: $$\tag{1} \square\, \bar{h}_{\mu \nu} = - \, \nabla^2 \, \bar{h}_{\mu \nu} = -\, 8 \pi G \, T_{\mu \nu}, $$ where $$\tag{2} \bar{h}_{\mu \nu} = h_{\mu \nu} - \frac{1}{2} \, \eta_{\mu \nu} \, h, $$ and $\phi = h_{00}/2$ is the newtonian potential. Playing a bit with these, and the energy-momentum of a static anisotropic fluid, give the following: $$\tag{3} \nabla^2 \, \phi = 4 \pi G (\rho + 2 \sigma + p). $$ For a cosmic string, tangential pressure is negative: $p = -\, \rho$, and orthogonal pressure is $\sigma = 0$, so the RHS of (3) is 0 (the string doesn't have a gravitational effect). For a cosmic wall we have $\sigma = -\, \rho$ and $p = 0$ so (3) is negative (the wall is repulsive).
But then I wonder how true is the conclusion. What if the string or wall is moving, twisting and deforming (non-static)?
Is it always true (I don't think so) that any thin cosmic string doesn't attract/repulse? And is it true that any thin cosmic domain wall is repulsive? What is the general case?
EDIT: We need to distinguish two motion states for the strings and walls: static and dynamical (i.e. with arbitrary motions). If the strings/walls are curvy and twisted, but still static, the above equations appear to say that the conclusion is still true (i.e. strings don't attract or repel, while static curvy walls are still repulsive). For dynamical strings/walls, the conclusion appears to be false.
Cham
  • 8,015
Small-scale dynamics of cosmic strings and membranes, “noise” or “wiggles” can contribute significantly to the energy and gravitational effects of these objects. To describe this we can introduce averaging over appropriately chosen small scales and obtain an effective stress–energy tensor in terms of large scale string/wall behavior.
For cosmic strings the effective equation of state turns out to be independent on the details of excitations and has the form: $$ U_\text{eff} T_\text{eff}=T_0^2, $$ where $U_\text{eff}$ is effective linear energy density, $T_\text{eff}$ is effective tension and $T_0$ is the (bare) linear energy density and tension of a unexcited (static) string.
If the effective energy density considerably exceeds the bare value, then the string would produce gravitational attraction mostly determined by this energy density.
The details can be found in the following papers:
  • Carter, B. (1990). Integrable equation of state for noisy cosmic string. Physical Review D, 41(12), 3869, doi:10.1103/PhysRevD.41.3869.
  • Vilenkin, A. (1990). Effect of small-scale structure on the dynamics of cosmic strings. Physical Review D, 41(10), 3038, doi:10.1103/PhysRevD.41.3038.
Similar wiggle-independent effective equation of state for domain walls (see e.g. here for the discussion): $$ \epsilon_\text{eff} \tau^2_\text{eff}=\tau_0^3, $$ is applicable only when the energy density does not significantly exceeds the bare value: $\epsilon_\text{eff}\approx \tau_0$. If this condition does not hold, then the effective averaged stress–energy tensor and, consequently, gravitational effect of such wiggly walls depends on the details of excitation spectra. But, again, if energy density exceeds bare values considerably, the net effect would be the gravitational attraction.
One should also keep in mind that generally, wiggly strings and domain walls would lose the energy of their excitations to various types of radiation (gravitational, scalar etc.). And details of such losses depend not only on the spectra of such excitations but also on microscopic structure of these objects, so the thin string/thin wall limit has inherent limitations.
A.V.S.
  • 17,324
