In Goldstein's Classical Mechanics, while introducing the Hamilton-Jacobi equation, he argues that the equation $$H(q_1, ... , q_n; \frac{\partial S}{\partial q_1}, ..., \frac{\partial S}{\partial q_n}; t) + \frac{\partial S}{\partial t} = 0$$ is a partial differential equation in $(n + 1)$ variables $q_1, ... , q_n; t$.
He then proceeds to say that the solution (if it exists) will be of the form $$S(q_1, ... , q_n; \alpha_1, ... , \alpha_{n+1}; t)$$ where the quantities $\alpha_1, ... , \alpha_{n+1}$ are the $(n + 1)$ constants of integration.
How is time a variable? Isn't it the parameter we're integrating over?
Perhaps this warrants some context. He introduces the Hamilton-Jacobi equation with the motivation to find a canonical transformation that relates the canonical coordinates at a time $t$ -- $(q(t), p(t))$ -- and the initial coordinates $(q_o, p_o)$ at $t = 0$. I hence get that time must be a variable here. However, it is still the parameter we integrate the Hamilton-Jacobi over in order to get $S$, right? Where does the $(n+1)^{th}$ constant of integration come from?
DentPanic42
  • 589
  • 16
the action function in the HJ formalism is dependent on time through the upper bound.
$$S(q_i,t,\alpha_i,t_0)=\int_{t_0}^tL(q_i,\partial_tq_i,t')dt'$$ in cases of Lagrangian that is independent (explicitly) of time then the constant of integration conjugate to $t$ let's call it $\alpha_t$ is simply the Energy.
read more here: https://en.wikipedia.org/wiki/Hamilton%E2%80%93Jacobi_equation#Hamilton's_principal_function
Tomka
  • 421
  1. The HJ equation is a non-linear 1st-order PDE in $n+1$ variables $(q^1,\ldots,q^n,t)$, namely the generalized positions and time, which in principle enter on equal footing.
  2. A complete$^1$ solution, known as Hamilton's principal function $S(q,\alpha,t)$, should not be conflated with the off-shell action functional $S[q;t_f,t_i]$ nor the (Dirichlet) on-shell action $S(q_f,t_f;q_i,t_i)$, cf. my Phys.SE answer here.
References:
  1. H. Goldstein, Classical Mechanics; Section 10.1 first footnote.
  2. L.D. Landau & E.M. Lifshitz, Mechanics, vol. 1 (1976); $\S$47 footnote on p. 148.
$^1$ A complete solution to a 1st-order PDE is not a general solution [1,2], despite the name!
