This question rises from the comments on @G Smith's answer's to this question https://physics.stackexchange.com/a/603032/113699
Precisely I was trying to understand the Lorentz Transformations between Spherical Polar Coordinates. The point is that I have read that Lorentz transformations have to be Linear but if for spherical polar coordinates they will be Non-Linear.
These answers here say that Interval preserving transformations/ Lorentz Transformations need to be linear Interval preserving transformations are linear in special relativity and Kleppner derivation of Lorentz transformation ( the answer by Selena Routley) and Why is this non-linear transformation not a Lorentz transformations? It does preserve $x^2 + y^2 + z^2 - c^2t^2 = x'^2 + y'^2 + z'^2 - c^2t'^2 $ ( especially Knzhou's comment on A Hussain's answer where he also says we should do SR in cartesian coordinates and not polar coordinates).
But the answer by Void here Are Lorentz transformations linear transformations?
says that Lorentz Transformations should be Homogenous and not Linear.
So my question is-
Can be there Lorentz Transformations between spherical polar coordinates or cylindrical coordinates. If yes, then they will be Non-Linear. So can the Lorentz Transformations be Non-Linear too?
Shashaank
  • 2,837
The Lorentz transformation is always linear in all co-ordinates, including polars.
I feel that the subtlety you may be forgetting here is that the Lorentz transformation always acts on the linear tangent spaces to a manifold at particular given points of discussion, not the manifold itself. Aside from in one special case ....
In special relativity, where we are always working in flat Minkowski spacetime, we can and almost always do use Cartesian co-ordinates to globally label the manifold in a one chart atlas. In this unusual situation, not only is the tangent space but also the manifold itself a linear (vector) space. So, in Cartesian co-ordinates, Lorentz transformations can, through this Cartesian co-incidence, be imparted to global co-ordinates to work out their images under Lorentz transformations. This is a special case and not a general property of Lorentz transformations or of manifolds.
If you choose polar (or other nonlinear images of Cartesians), even in Minkowski spacetime we don't have this luxury anymore and the Lorentz transformation $\Lambda:T_XM \to T_XM$ only has meaning as the linear transformation between the common tangent spaces $T_XM$ to the manifold $M$ constructed by two two relatively moving observers at the point $X$ where they are momentarily collocated. A tangent vector $A$ with contra components $A^j$ as seen by observer $\mathbf{A}$ naturally has components $B^k = \Lambda^k_{{}j} A^j$. And, as usual, if we want to construct the components of $\Lambda$ in polars $\bar{x}$ from the Cartesian components $x$, we invoke $\Lambda^k_{{}j}\mapsto \frac{\partial x^k}{\partial \bar{x}^\ell} \frac{\partial \bar{x}^m}{\partial x^j} \Lambda^\ell_{{}m}$, where the expressions of the form $\frac{\partial x^k}{\partial \bar{x}^\ell}$ are calculated from the derivatives of the polar in terms of Cartensian co-ordinate transformation in the wonted way.
I'm pretty sure i have made exactly this mistake too in the past, and it arises from the ubiquitous use of Cartesians in special relativity, which in turn makes us forget that Lorentz transformations do not usually apply to global co-ordinates. Of course, when you wish to do this latter, you concatenate $C\circ \Lambda \circ C^{-1}$ where $C$ is the nonlinear polar to Cartesian co-ordinate conversion. This is a nonlinear process and a simplification of the more general, nonlinear process of co-ordinate transformations between charts in a general manifold.
Selene Routley
  • 90,184
  • 198
  • 428
