To make a picture of what I am asking I have to use a comparission...So let say Adam walks on a 10km long bridge and wants to reach Sara at the end of the bridge but as he walks the Sun heats the bridge to gain length so it is then 10km and 10 meters long. For Sara waiting for Adam it seems he is a little bit slower than she expected assuming the velocity of Adam and his distance from her at the start. Is the same applied to a photon as Adam, space as bridge and planet Earth as Sara?
The answer of your question is simply No. Speed of causality in universe is constant (C) and hence, the photon doesn't "apparently slow down", but rather it's wavelength changes (in an expanding space time). See https://en.m.wikipedia.org/wiki/Redshift
The answer to this question is pretty obvious. The speed of light does not change. It will still travel the same amount of distance at the same time in the same medium. Just there will be one amazing thing going on. If you send a light beam from one planet to other planet which are moving far apart then the distance between them will be increasing so the light would take more time than expected. But this is not due to the decreasing speed of light but because of the increasing distance between planets. The same thing applies to this question. The wavelength of the photons tend to increase due time and this phenomenon is called "wavelength shifting" . You can look for wavelength shifting on Google and you can understand this phenomenon also.
AMAZING FACT: The speed of expansion of universe is continuously increasing and a time will come when this will be even greater than the speed of light.
- 101
