One end of a uniform rod of mass m and length l is supported by a frictionless hinge which can withstand a tension of (1.75mg). the rod is free to rotate in a vertical plane. To what maximum angle should the rod be rotated from the vertical position so that when left the hinge does not break? Answer is is $\cos(\theta)$ = $\frac{1}{2}$. Why can not this question be solved using centre of mass concept?
Asked
Active
Viewed 56 times
Why not? Loss of potential energy (measured at C.M.) goes to rotational K.E.(about axle). At bottom of swing, force from the hinge – weight, causes the centripetal acceleration of the C.M.
R.W. Bird
- 12,280
