Why is the direction of dipole moment taken from negative to positive charge when the field is directed in the opposite direction ?
It actually does not matter as long as you keep track of the signs. It was probably defined this way in order to give a similar formulation for torque
$$\vec{\tau} = \vec{r}\times\vec{F}$$
dipole moment is defined as $\vec{p} = q\vec{d}$ and torque on a dipole
$$\vec{\tau} = \vec{p}\times\vec{E}$$
If it was defined otherwise you had to write it down like $\vec{\tau} = \vec{E}\times\vec{p}$
Monopole
  • 3,404
