These are the knowledge points I got from online video.I finally found that there were some things I didn’t understand.
$\sum_n F_iR_i=\tau=I_{axis}a_z$,I learned from the previous video learning that the distance of R is the distance between each object and the axis of rotation.
BUT
The next video is in the derivation of angular momentum about rotation.Before that, it is necessary to derive the angular momentum of a point $a$ and the object(This distance is the distance between the point $a$ and the object).
Because the total momentum (here is $mv$) is zero, This has nothing to do with the selection of points, which can be selected at will.So for simplicity, the rotation axis is selected.
$l=r_ap=mr_a^2w$;$I=mr_a^2=I_{axis}$;$l=I_{axis}w$
Why torque only considers the distance of the the axis of rotation and not the point, while the derivation of angular momentum needs to go from point to axis.
