I'm struggling to understand the physical interpretation behind the field operators $ \phi(\mathbf x)$ and $\phi ^\dagger (\mathbf x)$ in quantum field theory. My understanding is $ \phi ^\dagger (\mathbf x)$ is an operator which creates a particle at a position $\mathbf x$. p37 of Quantum Field Theory for the Gifted Amateur (Lancaster & Blundell, OUP) says that from this definition of $\phi ^\dagger (\mathbf x)$, we can then write $$ \phi ^\dagger (\mathbf x) \propto \sum_{\mathbf{p}} a_{\mathbf p}^\dagger e^{-i \mathbf p \cdot \mathbf x}.$$ However this is different to the approach in Peskin & Schroeder. They write out the mode expansion for $\phi(\mathbf x)$ for the Klein-Gordon field (eqn 2.25) as $$\phi(\mathbf x) \propto \int \frac{1}{\left ( |\mathbf p|^2 + m^2 \right )^{1/4}} \left ( a_{\mathbf p} e^{i \mathbf p \cdot \mathbf x} + a_{\mathbf p} ^\dagger e^{-i \mathbf p \cdot \mathbf x} \right ) d^3 p.$$ I understand that we have two terms since we require $\phi(\mathbf x)$ to be Hermitian. However does this not contradict the definition that $\phi^\dagger (\mathbf x)$ creates a particle at a position $\mathbf x$ above? Is it correct to interpret $\phi(\mathbf x)$ as an operator that creates a particle at $\mathbf x$, or is it better to just ignore the interpretation and only think about the results the theory gives from performing measurements?
One could define the field operator either way. The representation with only creation/annihilation operator $$ \psi(x) \sim \sum_k a_ke^{ikx}, \psi^\dagger(x) \sim \sum_k a_k^\dagger e^{-ikx} $$ has the interpretation of creating/removing a particle at a particular time point, which is a convenient interpretation, e.g., for electrons. Representations with sum or difference of creating and annihilation operators $$ \psi(x)\sim \sum(b_k e^{ikx} + b_k^\dagger e^{-ikx}),\\ \psi(x)\sim \sum i(b_k e^{ikx} - b_k^\dagger e^{-ikx}) $$ are more convenient for bosonic fields, where in classical limit they reduce to the field strength (e.g., $E(x,t)$ for the electric field or polarization for phonons).
Roger V.
  • 68,984
