First of all, you need to understand from which root cause the spin appears in general. This root cause is a symmetry of the physical space-time.
Particles with different spins (I mean, spin-0 particles, spin-½ particles, spin-1 particles, and so on) use different representations of a symmetry group to map geometry of the space-time to their quantum spin states. Also, there is a difference between spin of a massive particle and of a massless one. The relevant part of the symmetry can be thought of as a Spin group, but in relativistic description of a massless particle it practically means SL(2, ℂ), whereas its subgroup SU(2) is appropriate for a frame of reference where the particle is at rest. In the latter case one can understand something about spin thinking about SU(2) only, that doubly covers the rotation group SO(3).
The two-state spin of an electron is controlled by the fundamental (weight-½) irrep. It means that 360° spatial rotation gives the same quantum state but with the opposite sign (180° phase shift). The projectivization of the ${\mathbb C}^2$ of state vectors gives the sphere $\mathrm{S}^2$; it is a usual sphere in the 3-dimensional real space.
The massive spin-1 particles a.k.a. vector bosons rely on the adjoint (weight-1) irrep of SU(2) that maps spatial rotations to rotations in ${\mathbb C}^3$ by the same angle, but the photon is not exactly a vector boson since it misses one spin state of the three. Moreover, the photon is massless; since it does not have any reference frame where it is at rest, one can’t understand anything about it in terms of SU(2) or SO(3).
A photon’s spin is similar to an electron’s spin in number of states – there are two. It means they carry the same amount of quantum information, the qubit, and are congruent informationally. But they are utterly dissimilar in terms of representations. You ask: what is the spin of a photon? In short: it is also an $\mathrm{S}^2$, but there are two distinct poles on it (left and right polarizations) and the equator between them (linear polarizations). You ask: why is it such a thing? Try to understand something in its (1, 0) ⊕ (0,1) representation. I do not understand this thing completely.
If you also are going to ask me “does a relativistic theory of spin of massive particles make sense?”, then I can answer: it does, but it is rather complex thing. You can read also about the bispinor representation and Dirac equation. One can describe the spin of a massive particle relativistically, but unlikely one can understand about it anything more than from a SU(2) theory.
