The Pauli exclusion principle states that no two fermions can share identical quantum states. Bosons, one the other hand, face no such prohibition. This allows multiple bosons to essentially occupy the same space, a phenomenon that has been theorized responsible for superconductivity. Bosons do not, however, occupy exactly the same space as can be readily observed by the fact that a Bose-Einstein condensate does not collapse into a singularity.
Both of the rather unusual examples cited above are inherent to low-energy systems. A large collection of $^{12}$C (e.g. in a diamond) does not exhibit particularly unusual behavior. This leads me to hypothesize that the energy distribution of the system is largely responsible for keeping bosons apart. Given the rather basic nature of the question, however, I figured someone here would likely know the "correct" answer. So,
what keeps bosons from occupying the same location?
AdamRedwine
  • 5,053
Er ... nothing prevents this. That's what a Bose-Einstein condensate is: lots of bosons in the same place and quantum state.
You are observing that the state is not perfectly localized, but that is a consequence of the state not being exactly zero momentum. Ultimately the Heisenberg principle puts a lower limit on how localized they could be.
If the bosons are composite objects (like Helium atoms, say) then you can write the state in terms of their constituent parts and the Fermionic bits have to obey the Pauli principle.
This is really just a comment to dmckee's answer, but it got a bit long for a comment.
The problem with your question:
is that no particle has a precisely defined position. Remember that when we get down to the sizes of atoms etc particles don't have a position. They are described by a wavefunction that may be localised in space to some extent but never localised down to a single point. As dmckee says, the Heisenberg Uncertainty Principle prevents a particle from being localised down to a point, unless that is you're prepared to allow the momentum to become infinitely uncertain in which case the whole thing turns into a black hole!
In a BEC all the atoms are in the same quantum state, but that state is only localised down to the size of the experimental apparatus. In principle you could make the size of the condensate smaller, but I suspect the increased uncertainty in the momentum would make it hard to keep the condensate coherent and it would break up into individual atoms of different energies.
John Rennie
  • 367,598
