So I wanted to ask a question that is a copy of Why can't you escape a black hole?
From the answers, the conclusion I draw is: it's impossible to escape a black hole.
any trajectory inside the event horizon is only pointing down. That's right, everywhere you look, you look down towards the center.
I realize that I can't imagine a 3D space that is curved onto itself. There has to be a vector connecting a dot with a center of the black hole, and opposite direction must lead further away from the black hole. Few questions that could help build up this intuition:
- Is there a 2D example of such space?
- Is the boundary of this closed space abrupt? like one nm above the event horizon there was still an "up" direction, and then it's suddenly gone?
- Does the inside of black hole has finite volume? what is it's volume?
- it should still be possible to see the light falling into the black hole from outside, where this light would appear to be coming from?
I have found following contradictory in the answers to the mentioned question:
- no local experiment can determine if you have crossed the event horizon.
- it's not possible to get any further from the black hole once you have crossed the event horizon.
Does this imply that you can't measure the distance anymore?
