I'm struggling with the following concept.
If we have a uniform beam with a single pivot at its centre, and we apply two forces in opposite directions on opposite ends creating a couple moment, then Newton's 2nd Law states that (because the forces cancel out) there will not be any motion (or at least transnational motion?)
But, of course, there will be rotational motion, as there is a net moment on the beam. I am struggling to connect the idea of Newton's 2nd Law and the forces together with rotational motion, as my intuition keeps telling me that there should not be any motion whatsoever as the forces cancel out.
Does this have to do with the internal forces of the beam? Is it because, in the transnational case, we are analysing the beam as if it is a single particle, but in the rotational case, we are analysing it as if it is a "line" of multiple particles, and therefore (if we look at the particles on either end of the beam) the net force is in a direction so as to cause rotation? If this is the case, then what causes the force on the particles on either end that accelerates the particle "inwards" in the normal direction and causes the signature "rotational" motion instead of the particle just accelerating off into space?
I hope I've gotten across what I'm confused about! :P
For a force couple, there will not be any translational motion of the center of mass but there will be rotational motion.
For translational motion, Newton's second law is
$$F=ma$$
For rotational motion, Newton's second law gives us
$$τ=Iα$$
Where
τ = torque and is analogous to force $F$
$I$ = moment of inertia and is analogous to mass $m$
$α$ = angular acceleration and is analogous to linear acceleration $a$
A force couple consists of two equal, but opposite parallel forces $F$ separated by a distance $d$. So the net force is zero (no translational motion) but the net torque or moment about the center between the forces is $Fd$.
No. It has to do with the motion of the beam as rigid body. On the other hand, moments on a beam are associated with internal stresses in the beam (a mechanics of materials problem).
From a dynamics perspective we are analyzing the beam as a rigid body. However, force couples do cause internal stresses in a beam when we analyze those stresses as a mechanics of materials problem.
Hope this helps.
Bob D
  • 81,786
