Unfortunately, for chemists, are curriculum is (usually) not as rigorous in the mathematics and physics as I would’ve liked. This (in my humble opinion) is a disservice to those looking to explore more physical areas of chemistry.
As an aspiring nuclear chemist, I need some recommendations for a good place to start to learn nuclear physics at a level that is beneficial for a chemist. Preferably books that are more suited for the autodidact with limited contact with outside resources that can aid in my studies.
Additionally if anyone thinks I should look into any books/subjects that may not be present in a chemists curriculum but is necessary to this subject, that would be appreciated along with the necessary math required for each.
I’ve only really just begun graduate studies so advanced classes in either field is essentially zero
Edit:
My (relevant) curriculum -
  1. Thermodynamics
  2. Quantum Mechanics
  3. Up to multi variable calculus
  4. Linear algebra
  5. Differential equations
  6. Mechanics
  7. Electromagnetism (freshman level)
Not sure about specific topics to cover in nuclear physics so a more broad introduction is preferred for a first book.
So, while there are related posts for learning nuclear physics, I will answer this one because you also ask about the background to going into nuclear studies. My background is in high energy physics, but I think I can at least point you in the right direction for self study. The first things you should get under your belt are a good study ofelectromagnetism, quantum mechanics, and particle physics. My recommendations for all of these at the upper undergraduate level are written by the same infamous author: Griffiths. Don't just read these books. So much learning is done by trying to work out the problems in the books. Here are the links for each of the respective books by Griffiths:
https://www.amazon.com/Introduction-Electrodynamics-David-J-Griffiths/dp/1108420419/ref=sr_1_2?dchild=1&qid=1605537882&refinements=p_27%3ADavid+Griffiths&s=books&sr=1-2&text=David+Griffiths
https://www.amazon.com/Introduction-Quantum-Mechanics-David-Griffiths/dp/1107189632/ref=sr_1_3?dchild=1&qid=1605537882&refinements=p_27%3ADavid+Griffiths&s=books&sr=1-3&text=David+Griffiths
https://www.amazon.com/Introduction-Elementary-Particles-David-Griffiths/dp/3527406018/ref=sr_1_5?dchild=1&qid=1605537882&refinements=p_27%3ADavid+Griffiths&s=books&sr=1-5&text=David+Griffiths
Then I think it would be beneficial for you to at least dabble in quantum field theory. Before you do that though, you should really be exposed to graduate level quantum mechanics. My go to text at that level is Sakurai/Napolitano's book:
https://www.amazon.com/Modern-Quantum-Mechanics-2nd-Sakurai/dp/0805382917
Be sure to get the newer edition which has a chapter on relativistic quantum mechanics. This is a heavy read though. It would probably take two semester to read through, so you might be able to get by with a lighter readying of it. For someone not looking to do theoretical physics, I would suggest learning quantum field theory from a book like "QFT for the Gift Amateur" by Lancaster/Blundell:
https://www.amazon.com/Quantum-Field-Theory-Gifted-Amateur/dp/019969933X
So finally, I can not personally recommend the text by Krane because I have not read it myself. However, every other post related to learning nuclear physics recommends the textbook by Kenneth Krane.
https://www.amazon.com/Introductory-Nuclear-Physics-Kenneth-Krane/dp/047180553X
Best of luck in your self study!
PaulPhy
  • 133
