15
Kerr metric has the following form:
$$ ds^2 = -\left(1 - \frac{2GMr}{r^2+a^2\cos^2(\theta)}\right) dt^2 + \left(\frac{r^2+a^2\cos^2(\theta)}{r^2-2GMr+a^2}\right) dr^2 + \left(r^2+a^2\cos(\theta)\right) d\theta^2 + \left(r^2+a^2+\frac{2GMra^2}{r^2+a^2\cos^2(\theta)}\right)\sin^2(\theta) d\phi^2 - \left(\frac{4GMra\sin^2(\theta)}{r^2+a^2\cos^2(\theta)}\right) d\phi\, dt $$
This metric describes a rotating black hole.
If one considers $M=0$:
$$ ds^2 = - dt^2 + \left(\frac{r^2+a^2\cos^2(\theta)}{r^2+a^2}\right) dr^2 + \left(r^2+a^2\cos(\theta)\right) d\theta^2 + \left(r^2+a^2\right)\sin^2(\theta) d\phi^2 $$
This metric is a solution of the Einstein equations in vacuum.
What is the physical interpretation of such a solution?
infinitezero
  • 1,520
Nikita
  • 5,757
  • 18
  • 51
It's simply flat space in Boyer-Lindquist coordinates. By writing
$\begin{cases} x=\sqrt{r^2+a^2}\sin\theta\cos\phi\\ y=\sqrt{r^2+a^2}\sin\theta\sin\phi\\ z=r\cos\theta \end{cases}$
you'll get good ol' $\mathbb{M}^4$.
16
This is presumably a flat spacetime described in funny coordinates. You can check this by calculating the Riemann tensor to see if it's zero. If I was going to do this, I would code it in the open-source computer algebra system Maxima, using the ctensor package.
user279733
  • 161
A reference which answers this is Visser (2008). It discusses the limits of vanishing mass $M \rightarrow 0$, and rotation parameter $a \rightarrow 0$. Your example is in $\S5$. Visser comments "This is flat Minkowski space in so-called “oblate spheroidal” coordinates...", as described in a different answer here.
