Does anyone know how to compute analytically or numerically the following integral (for $T=10^4$K)?:
$$n_\gamma=\frac{1}{\hbar^3\pi^2c^3}\int\limits_{2.1789\cdot 10^{-18}}^{+\infty}\dfrac{E^2\mathrm{d}E}{e^{\frac{E}{kT}}-1}$$
I tried with R, MATLAB, Maxima, Maple and Wolfram but I failed. I also search an analytical solution during a least a whole week....
Thx in advance for your help.
Andrew
  • 845
Sometimes computers have issues dealing with precision. Also try a change of variables like u=E/kT. Then factor out all the constants. So you get something like u^2du/(e^u-1) in your integral. This will simplify things in your numerical calculation. Once you calculate this integral, then you can just multiply back in the constants at the end.
Ali
  • 439
Sometimes, one just need to do a little work before the analytic software can handle the integration. Here is a suggestion. First write it in the form: $$ \frac{A}{\exp(Bx)-1}=\frac{A\exp(-Bx)}{1-\exp(-Bx)} . $$ Then expand the denominator $$ \frac{A\exp(-Bx)}{1-\exp(-Bx)} = A\exp(-Bx)\sum_n \exp(-nBx) . $$ Now you (or Maple, etc.) should be able to integrate every term after which you can resum the series.
flippiefanus
  • 16,824
