Consider the hydrodynamic energy-momentum tensor in 3 + 1 dimensions in at space with the Minkowski metric $\eta_{\mu\nu}$. The coordinates are chosen as $u^\mu = (t; x; y; z)$. To first order in derivatives, the energy-momentum tensor can be written as $T^{\mu\nu}=(\epsilon+P)u^\mu u^\nu+P\eta^{\mu\nu}-\eta\Delta^{\mu\alpha} \Delta^{\nu\beta}(\partial_\alpha u_\beta + \partial_\beta u_\alpha -\frac{2}{3}\eta_{\alpha\beta}\partial_\lambda u^\lambda)$
The velocity vector field $u^\mu$ is normalised to $u^\mu u_\mu=-1$ and pressure is a function of energy density, $P(\epsilon)$ (this function is the equation of state). The coeffcient $\eta(\epsilon)$ (also a function of energy density) is known as shear viscosity. The projector $\Delta^{\mu\nu}$ is defined as $\Delta^{\mu\nu}=u^\mu u^\nu + \eta^{\mu\nu}$.
(a.) Compute the trace $ T\equiv \eta_{\mu\nu}T^{\mu\nu}$
(b.) What would be the trace of the bulk viscosity term, which we set to zero from the start: $T^{\mu\nu}=\dots \zeta\Delta^{\mu\nu}\partial_\lambda u^\lambda.$
Could anyone lend me some advice?
John Rennie
  • 367,598
MRU
  • 175
First, the trace $\eta_{\mu\nu}T^{\mu\nu} = T^{\mu}_{\mu}$. Just swap the $\nu$ index in the Energy-Momentum Tensor to the bottom and set $\nu = \mu$.
With this we have $$T^{\mu}_{\mu} = (\epsilon + P)u^{\mu}u_{\mu} + P\eta^{\mu}_{\mu} - \eta\Delta^{\mu\alpha}\Delta^{\beta}_{\mu}(\partial_{\alpha}u_{\beta} + \partial_{\beta}u_{\alpha} - \frac{2}{3}\eta_{\alpha\beta}\partial_{\lambda}u^{\lambda})$$
As said, the contraction of the four-velocity $u^{\mu}u_{\mu} = -1$. Similarly we have $\eta^{\mu}_{\mu} = 4$ (just compute the sum manually)
Let's simplify the non-viscuous terms of the tensor first: $$T^{\mu}_{\mu} = 3P-\epsilon - \eta\Delta^{\mu\alpha}\Delta^{\beta}_{\mu}(\partial_{\alpha}u_{\beta} + \partial_{\beta}u_{\alpha} - \frac{2}{3}\eta_{\alpha\beta}\partial_{\lambda}u^{\lambda})$$
Now, let's compute the giant $\Delta$ term, since it's a bit long: $$\Delta^{\mu\alpha}\Delta^{\beta}_{\mu} = (u^{\alpha}u^{\mu}+\eta^{\mu\alpha})(u^{\beta}u_{\mu}+\eta^{\beta}_{\mu})$$ $$ = u^{\alpha}u^{\beta}u^{\mu}u_{\mu} + \eta^{\mu\alpha}u^{\beta}u_{\mu} + \eta^{\mu\alpha}\eta^{\beta}_{\mu} + u^{\alpha}u^{\mu}\eta_{\mu}^{\beta}$$ Using the raising and lowering property of the metric, $$ = -u^{\alpha}u^{\beta} + u^{\alpha}u^{\beta} + \eta^{\alpha\beta} + u^{\alpha}u^{\beta}$$ So $$\Delta^{\mu\alpha}\Delta^{\beta}_{\mu} = u^{\alpha}u^{\beta}+\eta^{\alpha\beta}$$
Thus $$T^{\mu}_{\mu} = 3P-\epsilon - \eta(u^{\alpha}u^{\beta}+\eta^{\alpha\beta})(\partial_{\alpha}u_{\beta} + \partial_{\beta}u_{\alpha} - \frac{2}{3}\eta_{\alpha\beta}\partial_{\lambda}u^{\lambda})$$
Here we have the the viscous term expanding: $$(u^{\alpha}u^{\beta}+\eta^{\alpha\beta})(\partial_{\alpha}u_{\beta} + \partial_{\beta}u_{\alpha} - \frac{2}{3}\eta_{\alpha\beta}\partial_{\lambda}u^{\lambda})$$ $$ = u^{\alpha}u^{\beta}\partial_{\alpha}u_{\beta} + u^{\alpha}u^{\beta}\partial_{\beta}u_{\alpha} -\frac{2}{3} u^{\alpha}u^{\beta}\eta_{\alpha\beta}\partial_{\lambda}u^{\lambda} + \eta^{\alpha\beta}\partial_{\alpha}u_{\beta}+ \eta^{\alpha\beta}\partial_{\beta}u_{\alpha} -\frac{2}{3}\eta^{\alpha\beta}\eta_{\alpha\beta}\partial_{\lambda}u^{\lambda})$$ $$ = u^{\alpha}u^{\beta}\partial_{\alpha}u_{\beta} + u^{\alpha}u^{\beta}\partial_{\beta}u_{\alpha} + \frac{2}{3}\partial_{\lambda}u^{\lambda} + \partial_{\alpha}u^{\alpha} + \partial_{\beta}u^{\beta} - \frac{8}{3}\partial_{\lambda}u^{\lambda}$$
From here, the fact that $u^{\mu}u_{\mu} = -1 \implies \partial_{\nu}(u^{\mu}u_{\mu}) = 0 \implies u_{\mu}\partial_{\nu}u^{\mu} = 0$, which kills the first two terms $$= \frac{2}{3}\partial_{\lambda}u^{\lambda} + \partial_{\alpha}u^{\alpha} + \partial_{\beta}u^{\beta} - \frac{8}{3}\partial_{\lambda}u^{\lambda}$$
From here, since everything's a dummy index, we can all relabel them to all be the same variable ($\mu$) and sum them all up: $$ = (\frac{2}{3} + 1 + 1 -\frac{8}{3})\partial_{\lambda}u^{\lambda} = 0$$ So, the trace of the viscosity term vanishes, and we are left with $$T^{\mu}_{\mu} = 3P-\epsilon$$
Now, for computing the extra term $T'^{\mu\nu} = \zeta\Delta^{\mu\nu}\partial_{\lambda}u^{\lambda}$, $$T'^{\mu}_{\mu} = \zeta \Delta^{\mu}_{\mu}\partial_{\lambda}u^{\lambda}$$ Our above computations can lead us to the fact that $\Delta^{\mu}_{\mu} = 3$ and thus $$T'^{\mu}_{\mu} = 3\zeta\partial_{\mu}u^{\mu}$$ Where $\partial_{\mu}u^{\mu}$ is the four-divergence of the four-velocity.
Kyle Perez
  • 301
