In Goldstein's Classical Mechanics, he suggests the use of Lagrange Multipliers to introduce certain types of non-holonomic and holonomic contraints into our action. The method he suggests is to define a modified Lagrangian $$L^{'}(\dot{q},q;t) = L(\dot{q},q;t) + \sum^{m}_{i = 1}\lambda_{i} f_{i}(\dot{q},q;t),$$ where $f_{i}(\dot{q},q;t)$ are $m$ equations of constraint, and $L$ the original Lagrangian. He then proceeds to define the action $S^{'} = \int_{t_{1}}^{t_{2}}L^{'}\,dt$ and takes the variation of $S^{'}$ to be zero, thus applying Hamilton's principle.
My confusion in this approach arises from the way in which the Lagrange Multipliers are introduced. I don't see why $\sum^{m}_{i = 1}\lambda_{i} f_{i}(\dot{q},q;t)$ should be introduced inside the integral.
In multivariable calculus, the Lagrange multiplier system stems from the idea that if we want to extremize a function subject to certain constraints, then the gradient of the function will be proportional to a linear combination of the gradient of the constraint equations. Here, the function in question is the action, not the Lagrangian. So, I feel like the resolution should be that $$\delta S + \delta \sum^{m}_{i = 1}\lambda_{i} f_{i}(\dot{q},q;t) = 0;\, S = \int_{t_{1}}^{t_{2}}L\,dt$$ and not $$\delta S^{'} = 0; \, S = \int_{t_{1}}^{t_{2}}L^{'}\,dt.$$
To me, it isn't clear if this makes sense or if the two methods are equivalent.
DentPanic42
  • 589
  • 16
  1. It should be stressed that the constraints $$f_{\ell}(q,\dot{q},t), \qquad \ell~\in~\{1,\ldots, m\}$$ depends implicitly (and possible explicitly) of time $t$, so we have continuously many constraints, namely for each instant of time $t$.
    Therefore we should introduce continuously many Lagrange multipliers $\lambda^{\ell}(t)$.
    And therefore we should sum $\sum_{\ell=1}^m$ and time-integrate $\int\! dt$ the term $\lambda^{\ell}(t)f_{\ell}(q,\dot{q},t)$ in the extended action. This fact seems to answer OP's main question.
  2. Finally, it should be stressed that Goldstein's treatment of non-holonomic constraints for an action principle is flawed/inconsistent, cf. e.g. this & this Phys.SE posts.
    Properly speaking we should therefore assume that the constraints $f_{\ell}(q,\dot{q},t)$ does not depend on the generalized velocities $\dot{q}$, i.e. that they are holonomic $f_{\ell}(q,t)$.
