This seems like a simple question, but I cannot wrap my head around it. If $\hbar = c = 1$ then length is time, and mass is inverse length or inverse time. Hence $G$ should have dimensions of length squared or time squared or inverse mass squared. But what would be its numerical value (since that is not set to 1) in these natural units ?
Marco
  • 179
This is correct. In this way, since $[G]=[M^{-1}L^3T^{-2}]$ in SI units, its dimensionality reduces to $$ [G] =[M^{-1}L^3T^{-2}] =[M^{-1}M^{-3}M^{2}] =[M^{-2}] . $$ This tells you that there is a product of powers of $\hbar$ and $c$ such that $G$ becomes an inverse-squared mass when you divide by it, and this product turns out to be $\hbar c$. This then gives us the correct expression: $$ G = \hbar c \times 6.7\times 10^{-57} (\mathrm{eV}/c^2)^{-2}, $$ as a valid identity in SI units, which then reduces to $$ G = 6.7 \times 10^{-57} \mathrm{eV}^{-2} $$ if you set $\hbar = c = 1$.
Emilio Pisanty
  • 137,480
