A questions goes like this:
X and Y are large,parallel conducting plates close to each other. Each face has an area A. X is given a charge Q. Y is without any charge. Points A, B and C are as shown in the figure.
To find the field at A, the solution goes; $E_A = E_1 + E_4 = \frac{Q}{4A\epsilon_0}$X$2 = \frac{Q}{2A\epsilon_0}$. The same is held true for the field at $E_C$.
How's this possible? If we label the surfaces from the left to the right as 1, 2, 3, and 4, wouldn't it be surface 3 that affects the field at A? And similarly, wouldn't surface 2 affect the field at C?
