Before closing it as a dupe of this. Please go through the question once .
Is it theoretically possible that quarks make up an electron ( like you may get a particle with the same electronic charge $(-e)$ with three down quarks however the binding energy for that down quarks triplet should be a great number since Dr jh pointed out that the mass of even a single down quark is greater than that of an electron) ?
According to This link, the mass of a down quark is approximately $4.8\; MeV$ . So after converting it into $kg's$ and multiplying by $3$ (since I considered three down quarks) , I got roughly $(256 × 10^{-31})kg$ . So the difference in the mass of an electron and three down quarks can be calculated (which is roughly $28 \; Times\; of \;mass\; of\; electron)$ and this serves as our binding energy . So , $E = (247) (9 × 10^{16}) J$.
Have the particle accelerators reached this energy level (since I have heard that the maximum number they reached is $7 \; TeV$) ? I don't know.
And Can this huge energy requirement be the reasons why we can't break down an electron ? Or am I misinterpreting something here ?
Ankit
  • 8,944
  • 32
  • 90
Yes! The electron definitely doesn't have to be fundamental. In fact the LHC does searches that rule out electron compositeness up to a certain energy scale.
If you're trying to make up the electron out of Standard Model (SM) quarks, you are going to run into problems:
  1. Why is the electron being bound together at such a higher scale than the typical strong force (or QCD) confinement scale? This suggests that the force holding the electron together is an exotic force. That means whatever quarks are living inside the electron need to be charged under this exotic force (we are now building a BSM model).
  2. If the exotic force confined to form the electron, when the exotic force confined, how do we know we didn't trigger QCD breaking? Worse, in your example, how do you know we didn't trigger electroweak symmetry breaking (EWSB) a la technicolor models? The electron compositeness scale has been ruled out up to scales far above the EWSB scale.
I'm not 100% sure you can't find a clever way to address these two points, but it's hard for me to see a fruitful model that manages to get around these constraints.
The easier way to build a model of a composite electron is to do it with truly exotic fermions that aren't charged under the SM QCD group. You can think of dark quarks charged only under a dark QCD that bind to form the electron.
Another question for further reading: how is the electron so light if its compositeness scale is so high? What happened to the binding energy? Baryons tend to be living at the scale of QCD confinement in the SM.
Well...
  • 189
An electron cannot be composed of quarks because quarks are affected by the strong nuclear force whereas an electron is not.
If you combine three down quarks so that they have the same negative charge as an electron, what you have is a particle called a "delta minus". We know that is not the same thing as an electron because it is more than $2000$ times as massive as an electron, and quickly decays into a pion and a neutron.
We believe (very strongly) that the electron is a fundamental particle because in all the millions (billions ?) of particle collisions observed at the LHC and other particle colliders, we have never seen an electron split apart into other particles or show any sign of internal structure.
gandalf61
  • 63,999
Electrons and the quarks are fundamental in that (as far as we know) they are not comprised of other particles. And you cannot form an electron from three down quarks (even though the total charge will be -1) because even one down quark is much more massive than an electron. And all protons are comprised of 2 up and 1 down quark meaning they all have the same charge to mass ratio. It is possible that quarks and even electrons are not elementary, but there is no evidence to suggest this possibility (the standard model would suggest the opposite).
Nevertheless still there is the possibility that the elementary particles may in fact not be elementary, but there is nothing thus far to show this to be true.
joseph h
  • 31,821
Sorry for this stupid question . I found the thing which I misinterpreted and where I made the mistake. I couldn't delete this question . So I am writing it as an answer.
Actually , the difference in mass is $(247 × 10^{-31} \; kg)$. So, the binding energy in this case would be
$ E = (247×10^{-31})(9×10^{16}) = 2223 × 10^{-15}$
And this is very minute when it comes to the energy of LHC's. This is actually a mathematical mistake which I did in my question .
Am I right ?
Ankit
  • 8,944
  • 32
  • 90
