The mass of Jupiter is about $10^{27}$ kg which, via $E=mc^2$, translates to $10^{44}$ joules. If one turned the planet into thermonuclear fuel in some way and detonated it immediately, about 1% or $10^{42}$ joules would be released. Because the diameter of Jupiter is about 130,000 km, the blast would last at least half a second or so. So we have $10^{42}$ joules per half a second. It's $2\times 10^{42}$ watts.
The Sun only releases $4\times 10^{26}$ watts of power, so the blast would be $2\times 10^{16}$ times stronger than the Sun. However, looking at the effects on the Earth, we must realize that Jupiter is about 5 times further from the Earth than the Sun, reducing the energy flux by a factor of $5^2=25$. So the half-second blast seems about $10^{15}$ times stronger than the sunshine. The equilibrium temperature is, because of the $\sigma T^4$ law, about $10^4$ times higher than that from the sunshine, about a million degrees.
The Sun warms the Earth by a degree in hours or so. A source that is $10^{15}$ times stronger obviously needs a tiny fraction of a second to reach thousands of degrees and evaporate the matter on the surface. So no doubt about it, the thermonuclear blast of Jupiter would burn and evaporate all nearby sides of all the planets – all of them are comparably far from the ground zero.
On the other hand, would the incoming energy be able to evaporate the whole Earth? We would be getting $10^{15}\times 342\times 4\pi \times 6,378,000^2\sim 2\times 10^{32}$ watts for half a second, about $10^{32}$ joules per the blast and per the surface of the Earth. The specific heats of materials are comparable to $1,000$ joules per Celsius degree and kilogram so we have $10^{29}$ kilogram-degrees to be heated. Divide it by the Earth mass below $10^{25}$ kg to see that you may still heat the material by tens of thousands of degrees by the incoming light. So I do think that this could evaporate the whole Earth but not the largest planets like Saturn.
Needless to say, the Sun itself would be pretty much untouched. Its surface already has 6,000 degrees or so. The strong radiation from Jupiter could bring it to a million of degrees, by the calculation above, but it's the same as the temperature of the interior layers. So the Sun would get destabilized a bit but it would quickly converge back to the Sun we know, I guess.
The calculations above are completely unrealistic because at most, one could think about turning Jupiter into a small star that would still burn very slowly and would be far weaker than the Sun.
