As implied from the question, does the sun rotate? If so, do other stars not including the sun also rotate? Would there be any consequences if the sun and other stars didn't rotate? Me and my friends have differing views on this, and would like some clarification. Thanks!
The sun does rotate. We can see the rotation of the sun by the doppler shift of the light we get from the sun.
(Image from this page.)
Since we know the characteristic spectrum of light from a hot body of a given temperature, we can use the same effect to determine if other stars rotate as well. Note that this only gives the spread in velocities along the line of sight, so a star may be rotating much more than the amount measured.
- 5,795
Yes, the sun and nearly all other stars do rotate.
One can see the rotation of the sun by looking at the motion of sunspots on its surface. Over time, the sunspots will move across the sun's surface - proof of its rotation. Furthermore, the rate of the sun's rotation is not constant throughout the sun; it is higher near the equator and slower near the poles.
Other stars rotate as well. To imagine why this would be requires some thought about the creation of a star. A star begins as an enormous cloud of dust and gas. When these clouds form, they always have some rotation - even if this rotation is incredibly small and imperceptible. Gravity, however, begins pulling the cloud together into a smaller and more compact object (a star). The shrinking of the large cloud into a smaller body hugely decreases its moment of inertia, causing its angular velocity to significantly increase by the conservation of angular momentum. (This is much like how a figure skater increases her rate of spinning by pulling in her arms.) Because of this, even the slightest hint of rotation of the large gas cloud is amplified into a rapid spinning once the compact star forms.
Rotation is notable in pulsars, which are rapidly rotating neutron stars. Rapidly spinning neutron stars produce magnetic fields, causing electromagnetic radiation (often in the form of X-rays). Beams of the radiation can strike Earth, allowing observatories to observe the rapidly pulsating stars.
- 2,720
- 3
- 19
- 34
Draksis' answer is more than enough...
Yes, it does rotate. There's an evidence similar to the sunspots. It's not much historical. Yet, we can observe it -The 2012 Venus transit. I noticed this in three of my images (1, 2, 3) which I got during the transit. These are the images from NASA's SDO, captured in the visible spectrum. On viewing these images consecutively, you can clearly see sun's rotation. Or you can also download their amazing video based on the same time-lapse. If you observe it closely, you can see the sun's rotation in the background quite relative to Venus.
Do other stars not including the sun also rotate?
Though Dan's answer provide an excellent evidence, Draksis' answer gives an amazing explanation. As far as we've observed, almost every celestial body in the observable universe rotates about its axis, due to the conservation of angular momentum $mr^2\omega$. As the distance (radius of orbital motion) decreases, $\omega$ should increase. Inertia does this automatically. Interstellar clouds (a few or few thousand LYs long) are massive enough to experience a gravitational collapse. Once this collapse leads to proto-star phase, the center is dense enough, so that the surrounding matter can swirl and finally spiral into it. As the lengthy cloud slowly spiral inwards it spins faster. Hence, almost all stellar objects spin.
Let's assume that the sun and other stars along with the planets suddenly stopped rotating themselves. There won't be a consequence or any effects now. (This necessarily doesn't happen due to conservation of angular momentum). But as Frank says (which according to the currently accepted hypothesis), if the clouds had stopped rotating (no initial angular momentum), there would be no proto-planetary disks surrounding the nebula-forming region, leading to a central non-rotating star with no planets. These proto-stellar disks are the accretion disks (dense arms of the clouds) which sometimes acquire enough density to form a star-like object (unable to fuse further) ending up as a planet.
- 9,178
The photosphere of the Sun rotates with a 25 day period at equator and more than a 36 day period at the poles. Below the photosphere we have the convection zone and below the convection zone everything rotate as it was one solid spherical body. This spherical body is 70 % of the volume of the Sun and even more of the mass and rotates with a period of 26,3 days. The surface of this sphere is called the tachocline and its extremely thin, less than 3% of the solar diameter.
Often magnetic confinement are used as a explanation of how the interior of the Sun can behave like one solid rotating spherical body, and the magnetic field are again hypothesized to come from motion in the convection zone, but this theory is not yet developed to level where it can fully explain what we observe.
Alternatively the interior of the sun is a fluid or solid body, but this conflicts with current fusion theory where the core of the sun is a hot, high pressure, nuclear fusion furnace.
Yes the rotation of stars have some implications, like neutron stars that rotate faster than a dentists drill. If they where made of ordinary matter the centrifugal forces would rip them apart, so we postulated that they where made of neutrons with huge gravity forces holding them together. Our Sun is the most spherical object we know of and we would excpect it to be like a compressed oval ball due to centrifugal forces, but current theory states that it is the magnetic field which confines the hot plasma ball into the perfect sphere we observe.
- 1,157
