-1
I know that when I use Gauss Law to find the electric field over a surface I get the value of the net electric field due to all the charges. But if I want to find the electric field only due to some of the charges (i.e. a part of the system), can I, hypothetically, "remove" those charges that I am not interested in and then apply Gauss Law to find the electric field due to the other charges?
Edit: By "remove" I mean can I, in fact, enclose a particular charge by my Gaussian surface, and still not count it as enclosed charge because I am not interested in the electric field due to that particular charge?
I believe you can arbitrarily draw a Gaussian closed surface around any subset of the charges. That's because any charges left outside the closed surface don't contribute to the net flux crossing the surface. Any field lines associated with the charges outside the surface go into one part of the surface and leave another for no contribution to the net flux.
In response to your edit, since the net flux crossing the gaussian surface equals the net charge enclosed by the surface divided by the electrical permittivity of the space, if you don’t count some of charge you will of course get a lower value as if the charge you didn’t count was never there, though I’m not sure why you would want to do that. Of course if you removed an equal amount of positive and negative charge, the net flux wouldn't change.
Keep in mind that although how the charge is distributed inside the surface doesn’t matter as far as net flux over the entire surface is concerned, it does matter if you want to know the net flux over part of the surface.
Hope this helps.
Bob D
  • 81,786
Whenever you are applying Gauss' law on any arbitrary Gaussian surface i.e.- $$\displaystyle \oint \textbf{E} \cdot \textbf{dS}=\dfrac{q_i}{\epsilon_o}$$ Here, the electric field on the gaussian surface is not just the electric field due to the charges inside the surface, it is also the electric field due to the charges outside. Gauss Law by itself, does not really care much about the field, all it cares about is the flux.
So coming to your question-
Yes you can, but first just make sure that there are no charges outside the surface, else Gauss law is of no use. Moreover, to find the electric field due to only some charges inside the cavity, you have to simply use the principle of superposition. Suppose you want to remove a set of charges $\{q_i\}$. What you have to do is, simply, hypothetically add the set of charges $\{-q_i\}$ to those exact places. This way, you will get a net zero contribution of electric field due to those charges. But do realize the fact that this happens only because electrostatics is linear in nature, the explanation of which we will save for another day. Of course this means the same as actually, physically removing those charges away from that place and keeping them at a large distance from the remaining charges. Now Gauss law will say- $$\displaystyle \oint \textbf{E}_{new} \cdot \textbf{dS}=\dfrac{q_{new}}{\epsilon_o}$$ in which the field is only due to the remaining charges. But it's still generally not possible to figure out the field at a point due to the charges left inside. Why? Because Gauss law cares only about flux, not about field. If your new configuration displays some symmetry that you can exploit, well and good, go ahead and find the field you desired. But if not, whatever we have done up until this point is pretty much useless.
Physiker
  • 1,469
Gauss law states that $$\displaystyle \nabla.\vec {\mathbf E} = \frac{\mathbf {Q_{enclosed}}}{\epsilon_0}$$
So as long as the charge is contained inside of the Gaussian surface, you can find the electric flux of it.
So to answer your question, yes, it is perfectly reasonable to that.
mnuizhre
  • 217
