For instance, a symmetric change from $(-,+,+,+)$ to $(+,-,-,-)$ in a metric, what are its physical implications? If there arent, why is that?
The only situation I know of in which the sign convention has physical implications is when defining the Clifford algebra. The full Clifford algebras of $+{-}{-}-$ and $-{+}{+}+$ signature are not isomorphic. One consequence is that when, like Dirac, you try to write the "square root" of the Klein-Gordon equation, which is $\partial^2\phi = -||\hat t||^2m^2\phi$, you get a factor of $\sqrt{-1}$ if $||\hat t||^2 = +1$, and have to complexify the algebra, while if $||\hat t||^2 = -1$ you don't have to. This is perhaps evidence that the universe prefers $||\hat t||^2 = -1$. Of course, Dirac chose the "wrong" convention, probably because he wanted the Dirac equation to look like the Schrödinger equation that he was trying to replace.
The even Clifford algebras of $+{-}{-}-$ and $-{+}{+}+$ are isomorphic, so you'll probably never find a meaningful difference between the two signatures in the physics of integer spin.
- 29,129
In standard general relativity there is no physical implication. It is merely a sign convention. You arrive at the same predictions either way. My preference is $(-,+,+,+)$.
There may be some differences in other contexts.
- 117,350
It depends on what OP means.
One on hand, if OP literally means going from a spacetime with 3 spatial and 1 temporal directions to a spacetime with 1 spatial and 3 temporal directions, then it obviously has enormous physical consequences. Closed timelike loops for starters, cf. e.g. this Phys.SE post.
On the other hand, if OP just means to change $\eta_{\mu\nu}\to -\eta_{\mu\nu}$ while at the same time change $ds^2=\eta_{\mu\nu} dx^{\mu}dx^{\nu}$ into $ds^2 =-\eta_{\mu\nu} dx^{\mu}dx^{\nu}$, then it is just a matter of conventions.
There is a separate issue with the definition of a Clifford algebra.
On one hand, a signature reversal changes the real Clifford algebra, cf. e.g. this Phys.SE post.
On the other hand, if OP just means to change $\eta_{\mu\nu}\to -\eta_{\mu\nu}$ while at the same time change the definition $\{\gamma_{\mu},\gamma_{\nu}\}_+=2\eta_{\mu\nu}{\bf 1}$ into $\{\gamma_{\mu},\gamma_{\nu}\}_+=-2\eta_{\mu\nu}{\bf 1}$, then it is again just a matter of conventions.
- 220,844
Answering: does the change in signature of the metric have a physical meaning.
Not for the example you cited. The example you cited is a choice of convention of which physics is independent. However this metric is very different from (+,+,+,+) or (-,-,+,+), as these do not differ by an overall sign. The former is known as Euclidean signature. Oftentimes physics in this signature is equivalent to physics in your (Lorentzian) signature but this equivalence is not guaranteed and is often unobvious and even enlightening. As just one example (out of many) the Schwarzschild black hole in Lorentzian signature is equivalent to polar coordinates (times a sphere) in Euclidean signature with the oddity that the origin is at $r=2GM$ (where $M$ is the mass of the black hole) instead of the usual $r=0$.
- 2,062
