There are a lot papers explaining why Laughlin's wavefunction are energetically favorable, but seldom explain why a lower energy state could explain the plateau at $\nu=1/3$. I met at several places claims like: a lower energy state at $\nu=1/3$ will pin the electron density at $\nu=1/3$. But why is that? And what actually it means? when we move $\nu$ from $1/3$ what happens? electrons adjust there distance or new particle been added? And is this a phase transition? Hope someone familiar this field could give me some help, thanks!
Knightq
  • 73
The Laughlin state alone doesn't explain the plateau. There is a lot more to the story.
Firstly at filling factor=1/3 the many-body ground state of the interacting electron gas is "approximately" the Laughlin wavefunction. By this I mean that the overlap between the Laughlin state and the numerically found ground state (for any realistic interaction like coulombic) is very large, i.e. their inner product is quite close to 1. Using the plasma analogy one can show that this state corresponds to uniform electron density. (See Girvin's Les Houches notes for details on Plasma analogy.)
Secondly the transport phenomena are decided by charged excitations in the system. For the filling factors 1/3,1/5,1/7,etc. the charged excitations are quasiholes and quasielectrons. While the former has a dip in the density profile at some point Z (say) in the 2D plane, the latter has the opposite thing in its density profile (as opposed to the earlier uniform case). The plasma analogy can again be used to show that these quasiparticles will have fractional e/3 charge in our case. (Atleast for now let us avoid justifying why they are excited states.)
Now lets say we are sitting exactly at 1/3 filling factor and then we add an electron to the system. It will break into 3 quasielectrons which can be separated at no extra energy cost (the idea of fractionalization). Similarly if some more electrons are added they will produce more quasiparticles. Now start thinking in terms of the 'semiclassical percolation picture' that is applied to electrons to explain Integer QHE (Again see Girvin's notes). Instead of electrons we give the same arguments using quasiparticles to explain the plateaus around 1/3 filling factor. The conductivities stop changing when the added quasiparticles are either going into the valleys of the disorder potential or are ending up on shorelines at the 2 well separated edges.
Let me clarify things a bit more. Think of starting with the 1/3 filling factor ground state. Now let us add adiabatically 1 flux quanta through a thin solenoid at the origin of space (See Laughlin's Nobel lecture). He shows that in this process e/3 charge flows towards the origin and gets collected there. Thus we have ended up with an exact ground eigenstate of the original hamiltonian + e/3 charge. So quasiholes are 'charged excitations', not the excited state when sitting at 1/3 filling. In fact the low energy gapped excitations at 1/3 filling are 'neutral collective excitations' (Again see Girvin's notes) and the existence of this gap is necessary for adiabaticity to work fine in the above thought experiment. (In the words of Laughlin the usage of the word quasiparticles here was "unfortunate".) Now if I just move the filling factor a bit in an experiment the new ground state is made up of new "quasiparticles".
