Are angular velocity, angular momentum and torque "real" vectors in the sense that acceleration and force are? Or are they only considered vectors to explain phenomena like gyroscope procession? Or are they considered vector quantities for other reasons?
It seems to be the case that we only assigned a vector to these rotational quantities because it's a convenient way to keep track of them. A disk rotating in the x-y plane would have an angular velocity vector along the z-axis. The faster the rotation, the "longer" the vector. If the rotation reverses direction, the arrow flips upside down.
But with things like gyroscope precession, the waters are muddied. Are these quantities really vectors? Or just bookkeeping constructs?
Hiro
  • 53
Torque, angular velocity and angular momentum are not inherently vectorial quantities.
One way to demonstrate that is to consider motion in some space with more spatial dimensions than our familian three spatial dimensions.
In a space with 4 spatial dimensions the following applies: to specify orientation of a state of rotation you need to specify the plane of that rotation. And obviously this extends to all higher dimensions.
In a space with 3 spatial dimensions it is equally the case that in order to specify the orientation of the rotation you need to specify the plane of rotation. It's just that with a space with 3 spatial dimensions every plane has a single vector that is perpendicular to that plane. Representation of angular quantities in vector form takes advantage of that opportunity.
This is why the vector representation of angular quantities needs a parity convention, in this case that convention is the right hand rule
In mechanics using vector representation for torque, angular velocity, angular momentum offers only limited explanatory power. The vector representation should be used as a bookkeeping device.
An angular momentum vector is an abstraction, it is an indirect representation. (Angular momentum is the linear momenta of all constituent parts of an extended object, integrated around the axis of rotation.)
For an explanation of gyroscopic precession see my 2012 answer to the question: What determines the direction of precession of a gyroscope? In that explanation the concept of angular momentum vector is not used.
Cleonis
  • 24,617
The vectors describing rotation are chosen along the axis of rotation because that is the only fixed direction in a rotating system. Given that choice, they do a good job of representing the magnitude and direction of rotational quantities, and as long as the axle remains fixed, they relate to each other and the various linear quantities in a straightforward and predictable fashion. With an axle that changes direction, I'm assuming that experiments were performed to verify that the vector formulas being used in two or three dimensions were giving accurate results.
R.W. Bird
  • 12,280
