12
I have searched everywhere I know to look but I cannot find out how Hamilton's equations deal with non-conservative forces. In my understanding, Lagrangian mechanics deals with this as follows: the Euler-Lagrange equations no longer have a zero on the right, they have a term $$\Sigma F_q$$ that is the sum of all the non-conservative forces encountered in the direction of the coordinate q.
\begin{equation} \frac{d}{dt} \frac{\partial L}{\partial \dot{q}} - \frac{\partial L}{\partial q}=\Sigma F_q(t) \end{equation}
The only document I have been able to find about how hamiltonian mechanics deals with non-conservative forces has been: https://doi.org/10.1007/BF00692025
It requires you to buy it and I felt like just the plain equations and a little context for an example like a box sliding down a hill against friction would be enough.
  1. If a variational formulation of Lagrange equations exists (e.g. because of the existence of a generalized velocity-dependent potential $U(q,\dot{q},t)$ for the forces in the problem), then we can in principle derive a Hamiltonian formulation via a Legendre transformation in the standard manner.
  2. If no variational Lagrangian formulation exists for Lagrange equations $$\begin{align}\frac{d}{dt}\frac{\partial L}{\partial \dot{q}^j}-\frac{\partial L}{\partial q^j}~=~&Q_j, \cr j~\in~& \{1,\ldots, n\}, \end{align}\tag{L}$$ but the Lagrangian $L$ is regular/non-degenerate, then we may still derive a Hamiltonian $H$ via a Legendre transformation. However Hamilton's equations get modified $$\begin{align} \dot{q}^j~=~\frac{\partial H}{\partial p_j}, & \qquad \dot{p}_j+\frac{\partial H}{\partial q^j}~=~Q_j, \cr j~\in~&\{1,\ldots, n\}. \end{align}\tag{H}$$ So there is no conventional Hamiltonian formulation. Nevertheless, several unconventional approaches exist, cf. this related Phys.SE post.
Lorentz force is an example of non-conservative conservative force that is discussed in pretty much any theoretical mechanics textbook. The Lagrangian is: $$L = \frac{m}{2}\dot{\mathbf{r}}\cdot\dot{\mathbf{r}} + q \mathbf{A}(\mathbf{r})\cdot\dot{\mathbf{r}} - q\phi(\mathbf{r}),$$ from which the momentum, the Hamiltonian, and the Hamilton equations follow as usual.
Roger V.
  • 68,984
